"82 KZ1000 run away rpm
  • ffltstn
  • ffltstn's Avatar Topic Author
22 Sep 2015 04:45 - 22 Sep 2015 10:28
#691310
Question is will a torn air cutoff valve cause the rpm to surge to 5000?
Bike has been running great. Had the throttle stick open (had to push them back down to close).
Took off carbs to check, never found anything.
Lubed the cable.
Carbs not sticking now.
Adjusted valves and replaced leaking gasket while I had them off.
After reinstalling the carbs Bike would start with choke and rev high. Turn off choke and would idle rough.
Found a few minor air leaks and fixed them. Started to sync carbs and could not seam to make any difference.
They would all the sudden rev to 4 or 5 thousand rpm. Had to shut it down to keep it from over revving.
Thinking still had vacuum leak but where?
Any other ideas?
Thanks,
Ken
'82 KZ1000
Mikuni BS34 carbs
135 mains
40 Pilot jet
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
Last edit: 22 Sep 2015 10:28 by ffltstn.
Re: "82 KZ1000 run away rpm
22 Sep 2015 05:23
#691320
Are carbs properly seated into the carb holders and clamps tightened?
Are all vacuum plugs/caps installed and in good condition?
Are any components of the stock clean air system fitted?
Question is will a torn air cutoff valve cause the rpm to surge to 5000? -- :unsure: What is an air cutoff valve ?
Good Fortune! :)
  • ffltstn
22 Sep 2015 10:32
#691384
Yes, Yes, No want to get it close before putting it all back together. It should run even without filters.
Air cutoff valve = coaster diaphragm, some carbs have them to stop popping when you get off the throttle.
After more reading i'm thinking stuck throttle plate or timing advance.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
  • ffltstn
Re: "82 KZ1000 run away rpm SOLVED
22 Sep 2015 14:32
#691422
Found the #3, and #4 carb boot screws were not tight as they could be.
Also found the screw for the #3 boot to the carb clamp would jam throttle.
Corrected both and shes running good so far.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
