Carburetor
  • big alfy
  • big alfy's Avatar Topic Author
Carburetor
10 Sep 2015 15:58
#689536
Hello , been awhile. I have an LTD1000/1327 low compression. 3x cams 900 falicon crank. 29mm smoothebores. I have 125 mian jets way too lean. Gonna try 135's. I bought 36 mm flats but they turned out to be junk. Are my 29's capable for that motor? The reason why my big block is low compression is I'm going with a ray Jay turbo next year. Missing a couple pieces for that. Just wondering if anyone heard of running 29's on big blocks...
  • 1977-Z1-A1-LTD
  • 1977-Z1-A1-LTD's Avatar
Re: Carburetor
11 Sep 2015 03:17
#689569
The 29mm smoothbore came stock on KZ1000's up until I believe 1978 or 1979. These guys make a kit to upgrade performance by increasing main jet size, modifying air flow through carb, and re-setting/re-placing the slide needle.
www.dynojet.com/jetkits/motorcycle/kawasaki.aspx
You may want to talk with their tech folks to see what options they have available.
1977 KZ1000 LTD
1990 FXR
1998 KTM 300 EXC
1974 CBR 350
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Carburetor
11 Sep 2015 05:24
#689584
FYI 29 Smoothbore never came stock on KZ1000 28mm Mikuni was stock on some models I have had nothing but good to say about Flat Slides you just have to get them tuned.
1984 750 Turbo
  • missionkz
  • missionkz's Avatar
Re: Carburetor
11 Sep 2015 08:22
#689601
KZ900-KZ1000 ... I think 76', 77', and 78' were all VM26SS 26mm carbs, .... yes? No?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Carburetor
11 Sep 2015 11:51 - 11 Sep 2015 11:51
#689618
missionkz wrote: KZ900-KZ1000 ... I think 76', 77', and 78' were all VM26SS 26mm carbs, .... yes? No?
Yes except I believe the '78 Z1R had VM28's.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 11 Sep 2015 11:51 by StreetfighterKz.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carburetor
11 Sep 2015 16:10
#689642
They'll work but tuning them for low compression could be a trial. Don't ask me how I know. What is it. Stock 1015 is 8.5/1.
