Part # for 34mm Cv carb screw driver
  • woodman
  • woodman's Avatar Topic Author
08 Sep 2015 12:47
#689195
Does anyone know the part number for the Motion Pro screw driver that you use to synch the 34mm Mikuni CV carbs on a GPZ750. It has an 8mm socket on the end and screw driver tip so you can loosen the carb adjusters and then tighten or loosen the screw. Not a very good description but I hope you can figure out the tool Im looking for, its a tough spot to get to without the tool
Re: Part # for 34mm Cv carb screw driver
08 Sep 2015 12:52 - 08 Sep 2015 12:54
#689197
Is this it (Motion Pro Part Number 57-8022)? I have one and it works pretty well on my VM carbs. I don't know if the CV carbs use the same tool. Ed
www.amazon.com/Motion-Pro-Carburetor-Adj...carb+adjustment+tool
Last edit: 08 Sep 2015 12:54 by 650ed.
  • jackleberry
  • jackleberry's Avatar
08 Sep 2015 12:53
#689198
I believe it is 15-0469
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • woodman
08 Sep 2015 14:03 - 08 Sep 2015 14:08
#689203
I think the one I need is 08-0022, but it looks to me that all 3 numbers are the same tool ?????????????????. Thanks guys
Last edit: 08 Sep 2015 14:08 by woodman. Reason: additional info
