Custom Air Box for KZ440.
Re: Custom Air Box for KZ440.
26 Sep 2018 16:08 - 26 Sep 2018 16:09
Most folks who ditch the stock air filter box put a small filter on the crankcase vent. The only problem you may encounter is an oily film on that part of the engine. Another alternative is to run a long hose from the vent to the rear of the bike. Little if any oil mist will travel that far. At least one guy here routed the hose to drip on the drive chain.
Last edit: 26 Sep 2018 16:09 by TexasKZ.
- newkzrider18
18 Nov 2018 12:43 - 18 Nov 2018 12:43
Does anyone know if the rubber boots were the inlet duct 1,4 part # 11015-063 or inlet duct 2,3 part # 11015-057? Also when installing these into the box, how well do they fit? It seems like they could move in and out, or is there a securing mechanism I didn't see?
At least from what I saw, you just cut a hole and fit the smaller end of the boot in and that's all (?)
Also, what is the tube at the top??
Thanks :]
Thanks :]
1980 KZ 440 LTD Model A
Last edit: 18 Nov 2018 12:43 by newkzrider18.
18 Nov 2018 13:44
The tube is for the engine vent and is connectet to the valve cover.
The following user(s) said Thank You: newkzrider18
- RoyB
22 Jan 2023 02:59
Hi all,
fascinated by this mod for my KZ440 LTD & had a go yesterday, unfortunately I can't seem to get the box to go high enough as the frame stops it (only by about 1/4" or so), if the box is any smaller I wouldn't be able to fit the boots properly? (that's why there's a nice angle on the original box.....).
Have been looking at possible ways of being able to move the box back by maybe 1/2", like fitting a flange.......?
Anyone else have any ideas?
cheers
Roy
cheers
Roy
- Sdaniels2010
18 Feb 2023 09:47Look at second page, third post down...are your airbox holes similar to what is in the pics, up near the top? Also, the airbox boots have a slight angle...if you have them angled the wrong way I can definitely see it making the box shift upwards.Hi all,
cheers
Roy
1981 KZ440 A2 LTD
- malavigne
08 Nov 2023 15:57 - 08 Nov 2023 16:20
I took inspiration from this thread and designed a 3d printed an airbox. If anyone wants to make one, the file is here:
cad.onshape.com/documents/90529535924d74...1e1da65dfb476e2aa3d9
i used a 2" fernco ($6 at the hardware store), cut in half as the boots. You can either rough up the fernco (flexible PVC) and use superglue, or just use a second gear clamp- i tried both and they both work well.
$20 of plastic sure beats buying an airbox that's older than me of ebay for $100s...
this thread took my un-useable new (to me) bike and made it run perfectly (as best i can tell, its my first bike). I did increase the pilot jets to #38's before replacing the pods with this intake, and have them still fattened up. I put an O2 sensor on the bike, so i have an OK idea I'm running well thru the ranges despite my complete lack of experience with motorcycles or carbs in general.
Thanks for everyones input in this forum, you've collectively saved my tons of time and money.
-Michael.
-Michael.
Last edit: 08 Nov 2023 16:20 by Street Fighter LTD.
The following user(s) said Thank You: JR, TexasKZ, Wookie58
- gd4now
- Denco where did you go?
08 Nov 2023 17:04
That looks very clean nice work in my opinion but what do I know?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
