o ring size for needle jet holder
- aenikolopov
17 Aug 2015 12:05
Hi all, I have a 1980 kz650f1 w stock vm24ss mikuni carbs. Can someone tell me the dimensions of the o ring on the needle jet holder? Not sure where to find that info, and one of mine is torn
Re: o ring size for needle jet holder
17 Aug 2015 12:20 - 17 Aug 2015 12:21
Which part in the image below do you need? Ed
Attachment 00003b-22.jpg not found
Last edit: 17 Aug 2015 12:21 by 650ed.
- aenikolopov
17 Aug 2015 12:57
I highly recommend you simply buy the genuine part, then you know they will work. Everything I read shows it is still available. Partzilla has them in stock for $1.13 each (see
www.partzilla.com/parts/detail/kawasaki/...vvsMcCFQsRHwodu0IKGA
), or your local dealer should be able to get them without a problem. The part number is 16038-016 see
www.dealercostparts.com/pages/oemparts#/...0-F1-1980/070055C-11
Attachment 00003d-7.jpg not found
17 Aug 2015 14:10
The o-ring fits onto the bleeder pipe.
Main-jet/bleeder-pipe o-ring: HF kit --- #008 - P5 - 4.8 ID x 1.9 W. ....... Z1Enterprises/Mikuni = 4.8 x 1.9
