Any quality carb kits?
- aphex
15 Aug 2015 10:19
Been looking around the internet for some carb kits for vm28s (pumpers) off a 1980 kz1000 ltd. Will be running them on a 1015 engine with pods and 4-into-2 exhaust.
I'm trying to find a source for quality aftermarket kits that are complete...needles and accelerator pump bits included, not just jets/gaskets/o-rings/needle valve sets.
Any such thing out there anywhere? All I see are cheap-looking kits from China or questionable kits from Japan.
1980 KZ1000 G1 Classic
1982 Yamaha XZ550, decommissioned
Re: Any quality carb kits?
15 Aug 2015 10:59 - 15 Aug 2015 11:01
Z1Enterprises.com kinda specializes in the Big Kaws, although they do carry stuff for many models.
Z1 lists mikuni parts for the VM29 & VM33 carbs, but I do not know if they have VM28 mikuni stuff.
Carb kits typically cover a range of models, so it's usually more efficient & often times cheaper to get the parts separately.
I could be wrong, but I don't think any carb kits will include the accelerator pump parts --- Z1Ent carries a K&L ap kit.
Note: K&L parts are made in Japan & oem quality imho. I've used a wide range of K&L parts which appear the same as oem & have performed well.
Last edit: 15 Aug 2015 11:01 by martin_csr.
- aphex
15 Aug 2015 16:22 - 15 Aug 2015 16:26
No eBay APP ID and/or Cert ID defined in Kunena configurationAwesome. Thanks for the reply!
I've been through z1 Ent., they don't quite have what I'm looking for but I will definitely keep them in mind for individual parts in the future.
Also, it appears you're right about kits not carrying the accel pump parts...and boy are those parts pricey! :blink: My experience with accel pumps has been that even slight wear of the diaphragms can cause nasty performance. I'd like to replace those asap. May go straight to K&L for that.
Here's the most comprehensive kit I have found. It has almost everything I'm looking for but the price looks too good to be true. Opinions?
Last edit: 15 Aug 2015 16:26 by aphex.
15 Aug 2015 19:02 - 15 Aug 2015 19:06
Z1Enterprises.com is usually helpful if you can't find something or if you're unsure of what to get. Be sure to mention the 1015 pistons & stuff like that.
That eebbaayy seller is somewhat deceptive imho --- he presents many parts as if they are oem, but most if not all of his stuff is aftermarket (which isn't necessarily a bad thing, depending upon the brand). I would ask if the kits are genuine Mikuni parts. Depending upon his answer, then I'd ask if they are K&L. And I would make sure the photos are of the actual kits. If he says K&L, you could compare his items to the K&L catalogue.
K&S & Keyster are a couple of other brands, but I don't know much about them. I kinda recall seeing a post somewhere in which the Keyster jet needles have the wrong taper, but it was an old topic, so who knows if that still applies. ???
The Sudco catalogue has a bunch of jet & needle info.
Last edit: 15 Aug 2015 19:06 by martin_csr.
