Petcock: Fuel flows in the "stop" position (kz400)
  • padgett
  • padgett's Avatar Topic Author
07 Aug 2015 12:53
#684801
Had this issue on the stock kz400 petcock. Fuel would continue to flow out of the petcock in the "stop" position.
Replaced the petcock with a new cb750 petcock today. same issue.
I'm testing the petcock off the bike.
Is this normal? I know the float needle will regulate the flow of gas into the bowls, but i'd assume the petcock would stop fuel flow...
Re: Petcock: Fuel flows in the "stop" position (kz400)
07 Aug 2015 13:58
#684807
Not trying to be insulting, but are you sure you are pointing the handle in the correct position? The big end of the handle (where the red arrow points in the image below) points to the setting. So in the image below the petcock is set on "RES". Ed
Attachment 00003a-78.jpg not found
  • padgett
07 Aug 2015 14:41
#684811
im mildly insulted.
yes its in the off position.
  • padgett
07 Aug 2015 14:49
#684812
would this have anything to do with testing it off the bike?
07 Aug 2015 14:59
#684814
Sorry about the insult; I have seen folks confused as to which end points to the position marked on the petcock.
With a manual petcock (ON; OFF; RES type) it shouldn't matter if the petcock is on or off the bike. If you attach a piece of tubing to the fuel line port, when the petcock is in the OFF position if you draw a vacuum on that tubing the petcock should no let air enter the tube. Ed
  • padgett
07 Aug 2015 16:41
#684825
I think that answers my question. Thanks for your time
  • Irish-Kawi
  • Irish-Kawi's Avatar
07 Aug 2015 16:44
#684826
650ed wrote: Sorry about the insult; I have seen folks confused as to which end points to the position marked on the petcock.
I think it's a valid point Ed, easy to check the simple things first and I actually struggled with this last night myself. Pops had to teach me exactly what you just pointed out, I was 180 degrees out. So I don't think it's unreasonable to check on, just my 2 cents though.
- Irish
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
