running to rich
  • canadien
  • canadien's Avatar Topic Author
Re: running to rich
08 Aug 2015 14:30
#684950
Actually mine have a 1.5mm cutaway
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: running to rich
08 Aug 2015 14:33
#684951
Do you have the P8's? The 75 came with the O8, 5J9-2nd, 1.5 cutaway and 17.5 pilots. Pic of the bike?
  • canadien
Re: running to rich
08 Aug 2015 14:39
#684955
I have a 1.5mm cutaway 17.5 pilot jet O-8 needle jet 5J9 jet needle I have the clip on the first groove and 115 main jet.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: running to rich
08 Aug 2015 14:48
#684964
Air box? I can barely see it. The forks look like a 76. Baffle? The carbs are set up for a 75. They ran a little stronger than the 73/74's and certainly better than the 76's.
  • canadien
Re: running to rich
08 Aug 2015 14:50
#684967
Stock air box. The fork are fron a 74 but the mounts for the reflector have been ground off
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: running to rich
08 Aug 2015 15:01
#684972
903 or 1015? Look up Mikuni USA
  • canadien
Re: running to rich
08 Aug 2015 15:06
#684976
903cc
  • canadien
Re: running to rich
10 Aug 2015 18:58
#685305
Thanks for the tip! I've got it running great now.
Couple of problems I thought I had tried the 17.5 pilot jets but they were # 20 on the pilot jet. Then I tweaked the air screws till it was smooth. I ended up having to move the jet needle to the # 2 position because it was a little lean on acceleration.
Now at 30mph the air mixture is 11.8:1. At 60mph its about 12.5:1. I guess thats as good as it gets.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: running to rich
10 Aug 2015 19:10
#685310
I ran my 28's for 20 years. No problems. I did have to change the float seats and needles when I went to 1015. Was running out of gas at WOT on the grade. I think I went from 2.0 to 2.5's.
  • canadien
Re: running to rich
10 Aug 2015 19:31
#685312
"2.0-2.5" Are there different size needle and seats aavailable? Or are you talking about something else?
Mine was 903cc now it's 983cc. So far the fuel doesn't seem to run out but I haven't rode it much yet.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: running to rich
10 Aug 2015 21:28
#685337
Yes, you can get larger seats. I ran them until I got my 33's. Always wanted to go bigger bore eventually.
