HELP! carb help for 79 kz 1000
- Kzhollen
- just a young hooligan with a bike and an ego
05 Aug 2015 19:31 - 05 Aug 2015 19:35
I let my kaw sit for about 5 months, it had been winterized, but now it won't hardly start. It will when choked but bogs down once choke is removed. Will run every once in a while but when given any throttel it bogs down. I've pretty much decided it carbs, but wanted a second opinion. I tore them down and deep cleaned them, jets and all, but to no avail.
"Just an angry young punk acting tame for societies sake"
Cali: 79 kawasaki kz1000. Yeah. Guess I like older girls.
Last edit: 05 Aug 2015 19:35 by Kzhollen.
- missionkz
Re: HELP! carb help for 79 kz 1000
05 Aug 2015 21:10
9 times out of 10 it is the carbs. I have never successfully cleaned any neglected carb by soaking and spraying carb cleaner.
Only three things really work and you must do all three.
1. Understand how the different circuits really work with respect to throttle position.
2. You must use very small diameter wires to force crud, caked into the small diameter of ports, fuel passageways, orifices and jets ... OUT.
3. Carb cleaner in a spray can to wash all this junk out after the wire treatment.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- baldy110
06 Aug 2015 09:06
If it only runs on choke then your carbs need to be cleaned. Did you store it with gas in the carbs?
- Kzhollen
06 Aug 2015 16:30
I've done these but maybe just not quite good enough. And baldy no I didn't, but my bike was found in a garage and was thrown in with the scrap by the original owner. It could have been sitting with fuel in it for 20 years. Thank you both for the help so far
- Kzhollen
07 Aug 2015 13:24
I went through the one fouled carb and sure enough, the jet was plugged. Oops. I also realized I had my plug wires wrong......now it runs on all four. Oops again. Runs great now, even picked up my girl from work
- 78z1Joe
- My man cave is my garage....
08 Aug 2015 19:21
Not only does he get his bike running right, but he also gets the girl!
is this a great site or what?
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
- PLUMMEN
08 Aug 2015 20:34
