Question About Carb. Rebuild Kit for 1987 KZ1000P
- jackleberry
Re: Question About Carb. Rebuild Kit for 1987 KZ1000P
23 Aug 2015 10:31bl_francis wrote: Man, that would be great if that's all it is.
It isn't. As I said, you could remove all these plugs and throw them in the trash and that still wouldn't cause gas in the airbox.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- ThatGPzGuy
23 Aug 2015 13:29jackleberry wrote:bl_francis wrote: Man, that would be great if that's all it is.
What he said. You have fuel in your airbox because the the float valve is stuck open or not adjusted correctly. Also, have you made sure your petcock is operating correctly? No fuel should flow with the engine off and the lever in the on or res position.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
23 Aug 2015 13:44
I'll add my voice to the others. Check your floats, needles and seats. Manual?
- yorkieUK
30 Sep 2015 11:26
Hi Guys.
I've been following this thread and have a question of my own.
I've just replaced my 127.5 main jets for 125. I also replaced some of the O-rings while I was at it.
Now I have the carbs back in, I'm not drawing fuel to the cylinders for ignition.
Did I need to prime the carbs before I refitted them?
1990 KZ1000P-9.
1990 KZ1000P-9.
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
30 Sep 2015 11:32
No. Assuming everything was re-assembled properly they will fill on their own when you put the petcock in the Prime position. Ed
- jackleberry
30 Sep 2015 12:00yorkieUK wrote: Hi Guys.
1990 KZ1000P-9.
Just curious, why the 125 jets? Is the rest of your bike stock? If you're doing it to improve fuel economy, can you report back with your results?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- yorkieUK
01 Oct 2015 05:13jackleberry wrote:yorkieUK wrote: Hi Guys.
1990 KZ1000P-9.
Yeah, I followed the guide on the thread below.
I changed the gearing before I toured Europe in the Spring and managed to get 120 miles from the tank instead of the previous 100 miles. The rev's are now lower when cruising at 70-85 mph and she still accelerates well off the line.
www.kzrider.com/forum/3-carburetor/50750...y-kzp-for-better-mpg
- jackleberry
01 Oct 2015 06:58yorkieUK wrote:jackleberry wrote:yorkieUK wrote: Hi Guys.
1990 KZ1000P-9.
Where did you get the 5FL51 needles?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
