KZ1100 project finalized, now tuning
  • eric951turbo
  • eric951turbo's Avatar Topic Author
03 Aug 2015 10:27 - 03 Aug 2015 10:28
#684066
Hey guys, I'm done with my project, now for the tuning. kz1100 a2 shaft 1982. Pods and aftermarkets installed.
The bike is running lean... hesitation on acceleration with some popping.... some popping in the exhaust on de-acceleration.
The bike runs better when the petcock is at the reserve position... if its at 'on' position, it runs very lean (no acceleration, stalls).
Carbs are clean, installed 2 size larger for main jets, and one size larger for pilot jet.
The air screws are rotated 2.5 turns out.
My questions:
1. the fact that the bike runs better on 'reserve' position, could be the symptom of a bad fuel petcock?
2. I bought a part bike that came with a new aftermarket petcock, but it has no return line nipple... if i replace it with that one, can i just leave the return line open routed under the bike?
first thing I was gonna try tonight after reading stuff on the web, was to enriched by turning the air screws, thats all i got for now.
here are some pictures of my bike
Attachment 11825073_10207381621928483_648742395009692259_n.jpg not found
Attachment 11811468_10207381622488497_4167641071387904267_n.jpg not found
Attachment 11828540_10207381622328493_8593038901482219972_n.jpg not found
Last edit: 03 Aug 2015 10:28 by eric951turbo.
  • baldy110
  • baldy110's Avatar
Re: KZ1100 project finalized, now tuning
03 Aug 2015 11:09
#684069
Check the vacuum side of the petcock for leaks.
  • eric951turbo
03 Aug 2015 12:21
#684079
no leaks on the vacuum side
  • jackleberry
  • jackleberry's Avatar
03 Aug 2015 12:45
#684082
Move the vacuum line to the petcock from carb #2 to carb #1 and see if that fixes it. (don't forget to move the plug to carb #2). If so, there's something wrong with cylinder #2 (stuck valve etc).
If not, then you probably need to rebuild the petcock. Kits are ~$30.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • eric951turbo
03 Aug 2015 13:25
#684085
Thanks for your help guys....
Is it normal that more fuel pass by when the petcock switch is on the 'reserve' side or not???
For me, it should be the same amount of fuel that passes by on 'reserve' and 'fuel' ???
  • jackleberry
03 Aug 2015 15:18
#684107
eric951turbo wrote: Thanks for your help guys....
Should be the same amount. The tube inside the tank on the petcock could be pluged with rust or whatever. There's supposed to be a screen in there to keep stuff out, but it may be mising, torn, melted etc. I wouldn't take it apart without the rebuild kit on-hand.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • eric951turbo
04 Aug 2015 14:06
#684294
OK... topic update.
I tried the bike again yesterday and played with the switch, reserve to fuel positions, and made no difference... so the petcock is not involved anymore in the problem.
The problems:
1. exhausts/mufflers pops a little from 0 to 3000rpm, with some hesitations for acceleration. when it its around 3.5k... the power is incredible like if it was turbocharge
2. on decelaration, my left muffler will pop a lot, until i press on the clutch
my guess is that I need to play with the air screws and try to adjust. I took the plugs out: #1 was a little white, #2 was totally suited black, 3and4 a little black... so I'm guessing I'm running rich.
My plan for tonight is :
1. check the carbs couplers, seal them with sealant
2. readjust airscrews to 2 turns
3. new plugs
  • spdygon
  • spdygon's Avatar
04 Aug 2015 14:15 - 04 Aug 2015 14:17
#684297
U may have to go up a size on the pilot jet.
Atleast that is what be needed in VM carbs.
I know yours are CV.
U mention your plugs are different color...that would till me that carbs are not working properly.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 04 Aug 2015 14:17 by spdygon.
  • eric951turbo
05 Aug 2015 18:04
#684528
New update.
I realized that the popping came for cylinder #4. If I unplug the plug on #4, the popping stops.
So far, I've:
1. Cleaned points
2. Swap wires and coil with another coil
3. New spark plugs (getting spark on all of them)
4. Compression good on all cylinders
After all this, no change
Any advice on where could be the problem, out of ideas here
  • Irish-Kawi
  • Irish-Kawi's Avatar
05 Aug 2015 18:59 - 05 Aug 2015 19:00
#684540
eric951turbo wrote: New update.
So far, I've:
1. Cleaned points
Hey Eric gorgeous bike! I know I'm brand new but read several threads past few days of guys running NGK plugs where it appeared like it was firing but was deceptively wrong. Any chance this may be plaguing you? I'm far from being an expert but your issue "sparked" that potential connection in my head and made me curious. Best of luck on resolving it ;)
- Irish
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
Last edit: 05 Aug 2015 19:00 by Irish-Kawi.
  • baldy110
  • baldy110's Avatar
06 Aug 2015 09:10
#684610
What jetting are you running and have you check the float levels? Also DO NOT use sealant on any carb fitting, it will not work. If the fuel fittings are leaking between the carbs you can use Teflon tape to seal the fittings.
  • eric951turbo
06 Aug 2015 11:08
#684630
Tks for comments.
Running NGK spark plugs and caps... But I've tried and swapped different sets, no difference, all good
+2 sizes bigger on main jet, +1 on pilot
I think I may have found the problem. My new air pilot screw... I think I may have bought the wrong ones from z1. The needles at the end of all 4 are a little bended .
I've replaced with the ones on the part bike I bought.
Unable to test now cause I need to fix the fuel tank
Thinking it might be the petcock, (before finding out about the air screws), I removed it and tried replacing with the brand new aftermarket petcock on the part bike.
It was a little dark in my garage and didn't notice that the aftermarket tube was larger.
I bolted it in tight, then I lift the tank and fuel was pouring.
Removed it and notice I blended the surrounding of the peacock hole on the tank.
Crap
Now I'm fixing it with epoxy jbweld
Crossing my fingers on all that crap
Brand new painted reservoir
Attachment image-7.jpg not found
Attachment image-8.jpg not found
