80 KZ750 Leaking Fuel Tee
  • disfinado@yahoo.com
  • disfinado@yahoo.com's Avatar Topic Author
  • 1982 kz750E
Re: 80 KZ750 Leaking Fuel Tee
03 Aug 2015 21:44
#684182
Thanks Randombeat. I can definitely take a picture, but I'm absolutely sure the float needle was in the correct position. I went through the carbs one by one checking for a vacuum leaks and the third carb was the only one that had a vacuum leak. I then narrowed it down to the float seat that was not holding any pressure upon a testing.
  • Nessism
  • Nessism's Avatar
  • Away
03 Aug 2015 21:55
#684185
Z1 Enterprises has the various O-rings to rebuild the carbs. I'd also get the O-rings for the pilot screws and floatbowls while you are ordering.
