1980 kz250 idle / choke / adjustment??
  • Vwnik
  • Vwnik's Avatar Topic Author
Re: Re:1980 kz250 idle / choke / adjustment??
27 Jul 2015 13:48
#683022
Adjusted air screw all the way in and still no go. Asked po for where he got the carb from to get more info from them on it
  • Vwnik
27 Jul 2015 13:56
#683023
Could timing be an issue ? Even if it idles great with choke on
  • TexasKZ
  • TexasKZ's Avatar
27 Jul 2015 15:11
#683031
Anything COULD be a problem. Do you have reason to suspect the timing?
  • Vwnik
27 Jul 2015 15:16
#683033
Only thinking timing because I haven't checked it since I bought the bike a week ago. Also because the no start electrical issue was due to the points being installed incorrectly.
But I found this for my carb -
Attachment ImageUploadedByTapatalk1438034619.653246.jpg not found
Apparently there is no choke--- it's a starter valve... Only to be used under necessity?? I don't have the necessity? So I guess it should stay with the plunger down?? Am I reading this right?
  • TexasKZ
  • TexasKZ's Avatar
27 Jul 2015 17:38
#683050
It would be a good idea to check the timing, but that does not account for the condition of the sparkplugs, nor the need to enrichner engaged to keep the engine running. The enrichner should only be needed to start the engine when it is stone cold, and for a VERY short time after starting. If yours is like the one in the picture, then pulling the lever up will close the starter system, pushing the lever down will open it for starting.
  • Vwnik
27 Jul 2015 17:44
#683052
Right. Lever up the bike runs- lever down kills it.
The bike hasn't ran since early spring so maybe it just needs to run a bit to help clear it ip
  • TexasKZ
  • TexasKZ's Avatar
27 Jul 2015 18:29
#683056
Has not run since spring??? If you live in the U. S., that explains much. Ethanol-laced fuel turns to barniclized smooge in as little as three or four weeks. That would explain why turning the low speed mixture screw had no effect. The only way to fix that is to completely disassemble the carb and carefully clean all those tiny passageways and jets.
  • Vwnik
27 Jul 2015 19:11
#683066
Southern ontario, Canada is were I am. But yes... Ethanol is such a crux if you ask me. Only premium up here doesn't have ethanol in it- but at $1.50/ litre it hurts
  • DGA
  • DGA's Avatar
Re: 1980 kz250 idle / choke / adjustment??
27 Jul 2015 19:21
#683068
Lever down LIFTS the choke slide OPEN. So it dies with the choke ON, this is not so bad.
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
27 Jul 2015 19:52
#683069
I understand it is a Mikuni carb, but what model carb is it? Ed
  • Vwnik
27 Jul 2015 20:31
#683073
Ed-
From the website it looks to be the vm series. PO purchased from dime city cycles.
