Soda blast 550 carbs?
- apbling
19 Jul 2015 06:33
Been thinking of soda blasting my 550 carbs and either 1 leaving them or 2 painting them. Question I have is do you think soda blasting is a little extreme for the tk-22 carbs? I made the mistake of lemon bathing my first set... It took the finish off them and they "dusted" everything. (If you touched them left hand your fingers silver).
- spdygon
Re: Soda blast 550 carbs?
19 Jul 2015 09:30
All of this parts have a protective coat. If u remove it ( soda blast ) u will need to protect the aluminum some how or with time you will notice white builtup.....corrosion.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
19 Jul 2015 13:55 - 19 Jul 2015 14:04
I've media blasted both BS CV Mikuni's and Keihin CV's before and they turned out great. There is no protective coating on them as near as I could tell. Understand that if you blast off any plating the steel parts will rust. I removed all the hardware and replated them before putting the carbs back together.
Last edit: 19 Jul 2015 14:04 by Nessism.
