Service manual question
  • TheForumTroll
  • TheForumTroll's Avatar Topic Author
10 Jul 2015 06:43 - 10 Jul 2015 06:44
#680292
I'm trying to understand the service manual at the chapter about the pilot system. It states (in factory settings table):
2 turns out
U (---)
(The U is inside a circle)
What does the parts after two turns out mean??
-[ KZ700-A1 '84 ]-
Last edit: 10 Jul 2015 06:44 by TheForumTroll.
  • TexasKZ
  • TexasKZ's Avatar
Re: Service manual question
10 Jul 2015 07:09 - 10 Jul 2015 07:10
#680295
I don't have it in front of me now, so I am flying Weak Memory Airlines.
Some of the settings and specifications vary from country to country, so Kawasaki developed a shorthand way to indicate the differences to avoid writing another sentence for each market's oddities. I believe what you are seeing is a cryptic way of saying that the U.S. EPA has decreed that low speed mixture be preset at the factory and any owner who fudges with it will become everybody's favorite date at the local prison.
In other words, in the U.S., it is not to be adjusted.
Ymmv
Last edit: 10 Jul 2015 07:10 by TexasKZ.
The following user(s) said Thank You: TheForumTroll
  • TheForumTroll
10 Jul 2015 07:22
#680297
I see.. That make sense, but what a way to write it :lol:
-[ KZ700-A1 '84 ]-
  • martin_csr
  • martin_csr's Avatar
10 Jul 2015 08:05 - 10 Jul 2015 11:30
#680304
If you're using the pdf manual, then a notation about U = US models at the bottom of the carb spec page may have been lopped off when the manual was copied or scanned. A number of pages of that pdf are poorly scanned.
Last edit: 10 Jul 2015 11:30 by martin_csr.
  • TheForumTroll
11 Jul 2015 14:56
#680421
I can't remember which one of them I saw it in. I'll have a look in the printed one.
-[ KZ700-A1 '84 ]-
  • martin_csr
11 Jul 2015 18:23 - 11 Jul 2015 18:24
#680443
There is a notation about it in the model specification section, pg 7 --- U : US model (pdf pg 10).
The 81 KZ650 manual has the notation directly below the carb jetting table.
Last edit: 11 Jul 2015 18:24 by martin_csr.
  • TheForumTroll
12 Jul 2015 01:34
#680479
Yeah I see them now. Is the (---) explained too?
-[ KZ700-A1 '84 ]-
  • martin_csr
12 Jul 2015 06:40
#680501
No. That's just one of those things that should be discerned.
