Kz1000J carbs on 82 GPZ 750?
  • Jrider
  • Jrider's Avatar Topic Author
05 Jul 2015 10:50
#679515
Has anyone run stock 1000J or police model carbs on a 82 GPZ 750? I ask because I know the jetting is different on the bikes even though the carbs are basically the same. If someone has done this, I would like to know how the bike ran. Does anyone have knowledge of this set-up? was it a matter of simply swapping the carbs onto the bike or did you have to make changes to the carb? I have a set of carbs from a police model on hand.
Thanks in advance
1982 Kawasaki KZ 750 R , Stock
2007 Harley Davidson Police Electraglide
  • Vince1966
  • Vince1966's Avatar
Re: Kz1000J carbs on 82 GPZ 750?
05 Jul 2015 11:29
#679517
If by chance you don't use those carbs I would be interested in buying them from you.
  • Jrider
18 Jul 2015 10:49
#681508
I,m Still trying to get an answer on this subject. Does anyone know if you can simply run the 1000J carbs on the GPZ 750 with no jet changes.I I know they are both the came carbs, just different jets in the 750.
  • Tyrell Corp
  • Tyrell Corp's Avatar
20 Jul 2015 05:07
#681760
Changing the jets and needles between the two is no big deal, adjusting the carb spacing (if required) is more. Sometimes you just need to try these things.
