Where do the fuel lines connect after carb?
  • MrBlue577
  • MrBlue577's Avatar Topic Author
29 Jun 2015 18:53
#678784
So I got my 78 kz400 a couple days ago off kijiji it's missing a few things but hey I can fix most of it. But I cannot figure out where the fuel lines connect after the carb... and I cannot find diagrams or videos or anything that make sense to me. Please help.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: Where do the fuel lines connect after carb?
30 Jun 2015 04:20
#678806
After the carb? Do you mean the drain hoses?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • martin_csr
  • martin_csr's Avatar
30 Jun 2015 04:57 - 30 Jun 2015 05:03
#678809
From the carburetor parts diagram at Partzilla for the 1978 KZ400-A2, there should be a fuel Tee between the carbs.
On the carb bodies kinda midway up, each carb should have a vent port --- connect tubing & leave it open to atmosphere.
The ports on the bottom of the carb float bowls are for the carb overflow/drain tubing. The tubing is usually routed behind the engine, forward of the swing arm and away from the chain & mufflers.
Kawasaki.com has the diagrams for your bike in the Owner Center section. PowerSportsWarehouse is another place.
Please note that some sites don't provide the full part numbers (bikebandit maybe?). The other sites I listed do.
Last edit: 30 Jun 2015 05:03 by martin_csr.
The following user(s) said Thank You: MrBlue577
  • TexasKZ
  • TexasKZ's Avatar
30 Jun 2015 06:05
#678819
The diagrams Martin mentioned are really helpful, but your best friend will be a genuine Kawasaki Factory Service Manual. They come up for sale online from time to time, and somebody here or over at the 400 forum may have an electronic version to share.
In other fuel related news, the fuel tank also hase a vent hose that should be routed to the same place that the carb vents and battery vent hose go. The petcock (fuel valve on the bottom of the tank) has two hose barbs. The smaller one (points to the rear of the bike I think) is for a vacuum hose that connects to the vacuum port on one of the carbs. The larger port (points toward the engine ?) is for the fuel line that connects to the tee Martin mentioned.
Oh yes, get a fsm.
  • martin_csr
30 Jun 2015 06:27 - 30 Jun 2015 06:27
#678823
His bike should have a manual fuel valve & I don't think there's a fuel tank vent hose. :)
Last edit: 30 Jun 2015 06:27 by martin_csr.
  • MrBlue577
01 Jul 2015 09:12 - 01 Jul 2015 09:19
#678951
Ok so here is the diagram that is closest to what i see on my bike without the lines connected. The t is already on my bike all that i was missing was the 4 lines coming off the carb. should my engine be starting or am i missing something?
Attachment bikefuellines.png not found
Last edit: 01 Jul 2015 09:19 by MrBlue577.
  • martin_csr
01 Jul 2015 14:23
#678982
Have you ever seen the bike run? Not starting could be any number of things.
The missing vent & overflow tubing shouldn't have anything to do with it not starting.
  • Zephyrrider
  • Zephyrrider's Avatar
01 Jul 2015 15:27 - 01 Jul 2015 15:36
#678987
All 3 models from 78 - A2,B1 AND C1 have manual fuel valve/tap/petcock and No tank vent
Main fuel line from T join to tank - overflows and drain bowl tubes not necessary .
Cant quite see on my diagrams - you should have 1 Brass nipple at the front and on top of each carb - these are to use a x 2 manometer (Carb Sync) - your models are slightly different to here in carb setup - do you have caps on the brass nipples i mentioned or rubber tubes coming off them ? :)
Mick
1994 ZR750 Zephyr C4.
Last edit: 01 Jul 2015 15:36 by Zephyrrider.
  • martin_csr
02 Jul 2015 06:02
#679090
Instead of the typical vacuum nipples, I think his carburetors have vac screw plugs in the vac ports.
I'd guess he'd need to remove the screw plugs & attach vac nipples, then the carb sync tool. ???
  • Zephyrrider
02 Jul 2015 15:49
#679145
Martin - same as my old 900 Rol'Dor with the screw in plugs for sync (possibly). None of the diagrams show these unfortunately .
MR Blue i have a FSM PDF, but unfortunately it is for KH 400 (and KH 250) from 1972 - 1976 so Mikuni carbs but it may be of some use till you get the correct one - i can put it on Drop Box for you if you like. 17.1 Meg .
Mick
  • martin_csr
03 Jul 2015 06:10
#679214
The carb parts diagram for his 78 400-A2 shows the screw plugs but doesn't identify them as vacuum plugs which I think they are. not really sure.
