High end troubles
Re: High end troubles
24 Jun 2015 10:51
Being it's not engineered for that, I can't tell you. I rode for a year like that. Platinum plugs, better, BP8ES NGK's. didn't foul as fast, smaller pilots, even better. At last I got everything I needed one piece at a time, valves, springs, valve guide seals and gaskets. Smoking stopped, Didn't really smoke except on start up. Just a puff. Now it was too lean. OK start over. It runs great and soon when I put in my 10.25/1 pistons, I'll dial it in for good. :woohoo:
24 Jun 2015 10:54
My story above is meant to illustrate how oil burning can effect jetting.
- KZB2 650
25 Jun 2015 05:39 - 25 Jun 2015 05:43
Stock position for the nettle is in the 4th groove (second from the bottom) from the factory on a KZ650 ......... I have mine in the lowest 5th groove with the 700cc kit 750 cam, pods and header.
The carb kit you bought that had the 118 mains in it .... did it have nettles too ? Those are different from the stock ones too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 25 Jun 2015 05:43 by KZB2 650.
25 Jun 2015 06:09
Go back to stock and start over. Aftermarket jets are drilled differently. Mixing them and stock parts is an error. Use their jets and needles or get your own Mikuni ones. I'd take out the nossles and see if they are the stock ones too. Who knows what the PO did and you may be shooting blind here.
