cv32 issues
Re: cv32 issues
22 Jun 2015 08:24
A look at the plugs at least. Any rust, tear it down.
- TheForumTroll
Re: cv32 issues
22 Jun 2015 10:09 - 22 Jun 2015 12:03
If it is because of water, how does the tank look?
Morbid curiosity, do you have more pictures?
EDIT: Posted the picture in another forum. The consensus there seems to be that gas with high level of ethanol causes this..
-[ KZ700-A1 '84 ]-
Last edit: 22 Jun 2015 12:03 by TheForumTroll.
Re: cv32 issues
22 Jun 2015 15:27
I doubt that. I've seen carbs like that when bikes have been sitting outside for a long time. Yes, more pics.
- oreis
Re: cv32 issues
06 Jul 2015 21:19
sorry guys I've been so busy with work and i forgot i posted this i ordered some mikuni 32mm carbs came with new intake boots throttle cable and filters. The plugs looked good and the oil looked good as well, the engine turns over easily and it builds compression. I'm going to get a bore scope from work and look into the cylinders. The tank is clean and dry thinking about cleaning it again before i put fuel in it, do you guys want more pics of the carbs or anything in particular? I'm not to upset about what I've found so far since I got this bike for such a steal but theres a few things i won't be using. if i can find gaskets ill pull the heads still trying to source seats for my brake caliper and petcock
Re: cv32 issues
06 Jul 2015 21:35
Get a in line filter.
- oreis
