Carb overflowing ... again!!!
  • RFE81LTD1K
  • RFE81LTD1K's Avatar Topic Author
19 Jun 2015 03:15 - 19 Jun 2015 03:16
#677235
OK, I'm picking this up where I left of in my electrical issue thread in which later moved to a carb issue. The electrical issue is fine now. The carb issue isn't. Or at least it wasn't till I pulled the carbs again today. For the second time in a week I had a carb overflowing. The first time I found a pc of trash in the seat of #3 carb. Removed the trash and polished the seat all was good. Now this second time (#4 cyl) I removed all of the seats to check um for trash and polish all of them this time. What did I find ... remember telling me about a sliver of fuel line getting cut off from the inside when installing it onto a hose barb ... Yeah. That's exactly what I found sitting in the bottom of #4 seat. Bike runs great now. Except for the new clutch started slipping today.
Yeah, I know ... wrong forum for clutch problems. I'll make it short by saying I think the adjustment screw was too tight. I set it while the engine was cold and have now re-set it while hot. Haven't tested it yet but will tomorrow. If I still have a slipping issue I'll start another thread on it.
Robert
81 KZ1000 LTD
All original.
15k miles.
Last edit: 19 Jun 2015 03:16 by RFE81LTD1K.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carb overflowing ... again!!!
19 Jun 2015 07:36
#677259
Have you replaced your fuel lines? They can come apart with age you know.
  • pete greek1
  • pete greek1's Avatar
19 Jun 2015 09:20
#677271
what oil are you running in the motor?? ..is JASO/MA certified ? ...if not, then that could be making your clutch slip
Pete
  • RFE81LTD1K
19 Jun 2015 11:41
#677285
swest wrote: Have you replaced your fuel lines? They can come apart with age you know.
Yes. Twice in fact because I didn't like the way I ran it the first time.
As for oil ... Castol GTX 10-40. (not energy conserving) Thinking about changing to Chevron Delo 15-40.
81 KZ1000 LTD
All original.
15k miles.
