plug reading.. Pic Mikuni CV Question edited
- 76KZ900
13 Jun 2015 15:31 - 13 Jun 2015 22:01
Ok somewhere along the line I picked up a stumble/miss when letting clutch out in gear. It misses stumbled and so on. After that it's fine and it idles ok. Sitting in neutral it revs fine. I removed carbs , cleaned pilot jets. Blew through carbs with carb cleaner. Actually soaked jets in carb dip then blew through them. Also took out 148 mains. It was running crazy rich. Pilots are factory 37. Plugs still look dark sooty with 127.5 mains. Synced carbs and checked float level. Complete dyna ignition, coils and all. Any ideas on where to look ?
Ok so I took it out and ran hard on expressway.. Seemed to be pretty lean ... I know plugs look black but see how quick tips burnt the soot off after hard run... I upped jets to 135 mains... Pulls like a different bike... real hard...
Now for next and most important question... While I was changing main jets I noticed the one carb that seems to be puffing back through carb Needle jet falls out down toward plunger when I remove the main jet, I read where these are a slight press and need to be pushed out by loosening jet and pushing them out... I assume its not supposed to fall out. looked up on partzilla didn't look like o ring on part.
so is this a problem ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 13 Jun 2015 22:01 by 76KZ900.
- missionkz
Re: plug reading.. Pic
13 Jun 2015 19:51 - 13 Jun 2015 19:52Even with pods and headers, I can not run anything larger then 120 mains and 20 pilot jets ... and even that was when closer to sea level.76KZ900 wrote: Ok somewhere along the line I picked up a stumble/miss when letting clutch out in gear. It misses stumbled and so on. After that it's fine and it idles ok. Sitting in neutral it revs fine. I removed carbs , cleaned pilot jets. Blew through carbs with carb cleaner. Actually soaked jets in carb dip then blew through them. Also took out 148 mains. It was running crazy rich. Pilots are factory 37. Plugs still look dark sooty with 127.5 mains. Synced carbs and checked float level. Complete dyna ignition, coils and all.
Now at 5280 ft above sea level, I am using 115mains, 20 pilot (considering 112.5 mains and 17.5 pilots), stock needle clip position and about 1 1/2 to 1 3/4 out on the mixture screw.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 13 Jun 2015 19:52 by missionkz.
- 76KZ900
13 Jun 2015 22:03missionkz wrote:Even with pods and headers, I can not run anything larger then 120 mains and 20 pilot jets ... and even that was when closer to sea level.76KZ900 wrote: Ok somewhere along the line I picked up a stumble/miss when letting clutch out in gear. It misses stumbled and so on. After that it's fine and it idles ok. Sitting in neutral it revs fine. I removed carbs , cleaned pilot jets. Blew through carbs with carb cleaner. Actually soaked jets in carb dip then blew through them. Also took out 148 mains. It was running crazy rich. Pilots are factory 37. Plugs still look dark sooty with 127.5 mains. Synced carbs and checked float level. Complete dyna ignition, coils and all.
Im running CV carbs ... This is for a 83 KZ1100LTD shaft. Not the 900 as my name implies
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- 76KZ900
13 Jun 2015 23:52 - 13 Jun 2015 23:53
This is the part that falls out.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 13 Jun 2015 23:53 by 76KZ900.
- missionkz
14 Jun 2015 01:53
OK, Oops. Yeah that's different then the carbs I was thinking on a 900.
I think that is an emulsion tube.
Not sure how to keep it installed if loose but it would be bad if it kept falling out while the engine
is running.
is running.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- 76KZ900
14 Jun 2015 02:38
Well jet holds it in while carb is together but as soon as you take main jet out it falls down toward slide. I'm not real experienced with cv carbs And that's the carb I'm getting a puff back thru when bike is at low rpm
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- daveo
14 Jun 2015 09:0676KZ900 wrote: Well jet holds it in while carb is together but as soon as you take main jet out it falls down toward slide. I'm not real experienced with cv carbs And that's the carb I'm getting a puff back thru when bike is at low rpm
It will only fall out when you have the carbs upside down, and get pushed up when installing the jet from bottom. Insert the jet very carefully for the initial thread catch, and it may stay in-place. Otherwise (with carbs off the engine), you can hold it down with a finger tip from the in-feed side while threading the jet in with the other hand.
1982 KZ1100-A2
- 76KZ900
14 Jun 2015 13:44daveo wrote:76KZ900 wrote: Well jet holds it in while carb is together but as soon as you take main jet out it falls down toward slide. I'm not real experienced with cv carbs And that's the carb I'm getting a puff back thru when bike is at low rpm
What I need to know.. Is should it FALL on it's own with jet out?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- 76KZ900
14 Jun 2015 13:47daveo wrote:76KZ900 wrote: Well jet holds it in while carb is together but as soon as you take main jet out it falls down toward slide. I'm not real experienced with cv carbs And that's the carb I'm getting a puff back thru when bike is at low rpm
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- daveo
14 Jun 2015 16:32 - 14 Jun 2015 16:35
Yes...sort of
:huh: With the slide and jet needle removed, the needle jet pushes up easily, without the main jet holding it in-place. The notch in the side orients the needle jet position and keeps it from turning while the main jet is threaded in.
1982 KZ1100-A2
Last edit: 14 Jun 2015 16:35 by daveo.
- 76KZ900
14 Jun 2015 18:02
ok cause the other three in this set of carbs had some tension or press holding them in with out jet in. Same as other set of cv carbs from suzuki I cleaned. Wasn't sure if there was something to make it fit tight.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
