Richer Jetting on the Inboard Carbs?
  • VTEC
  • VTEC's Avatar Topic Author
Re: Richer Jetting on the Inboard Carbs?
15 Jun 2015 18:25 - 16 Jun 2015 16:27
#676729
Yeah, I thought about running the lines under the tank or around the side, but underneath like the Eddie Lawson edition turned out to be the best route. No problem on drain back. I also have a gauge at the pressure test port. Pressure is right there on start up, and that's after the cooler going up to the head.
KZ1000-K2
ZRX1100
XR400R
Last edit: 16 Jun 2015 16:27 by VTEC.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Jun 2015 20:16
#676741
The big end gets the oil first. I too a have gauge at the test port. Looks good, pic of the whole bike?
I blew out two Doremi gauges. Had to go with a Sportster one. 60 PSI.
  • VTEC
16 Jun 2015 16:48 - 16 Jun 2015 16:51
#676861
swest wrote: The big end gets the oil first. I too a have gauge at the test port. Looks good, pic of the whole bike?
Hey Steve,
Here's my KZ. Bought it new for $3,250, I was 20 years old at the time. Resurrected it a few years ago when the oil gushing out the head gasket was saturating my shoes.
I did the same thing you did with the "D" gauges. Went through two, and discovered that they came apart from engine vibration the first time you hit red-line.
So I went with this liquid filled Marshall 0-15psi gauge.
The liquid filled can handle the vibration, but not the heat. As engine temperature rises, the pressure reading decreases due to the liquid expanding from heat. I even spoke with the tech guy at Marshall. And he said the best I can due is bleed the gauge when fully hot to relieve the pressure. Then it would be accurate hot, and read way high cold. Which is probably the better of the two, but I haven't tried it, and burned my hands, yet.
I did find this very cool gauge/test port adapter at JPcycles.
KZ1000-K2
ZRX1100
XR400R
Last edit: 16 Jun 2015 16:51 by VTEC.
  • Tyrell Corp
  • Tyrell Corp's Avatar
16 Jun 2015 17:05
#676862
i had a glycerin filled ebay temp guage, looked cool but didn't last. Not sure if heat or vibration killed it. less is more sometimes.
A word of warnig about this cheapo chinky ebay anodised aeroquip AN hose fittings. I had a 90 AN -8 swivel fitting, blew through it with a thumb over the end to check it and it leaks like a sieve. I used it on a low pressure oil breather vent, no probs. Risk it for adaptors and spacers maybe but any critical oil/fuel/turbo applications should have decent branded fittings imo.
The 'proper' forged anodised miltary spec aerospace fittings are expensive for a reason. False economy crashing a £20 million 747 for a chinky £1.99 fitting.
  • VTEC
16 Jun 2015 17:11 - 16 Jun 2015 17:28
#676866
Hmmmm...no leaks so far. The fittings all came from Earl's.
KZ1000-K2
ZRX1100
XR400R
Last edit: 16 Jun 2015 17:28 by VTEC.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jun 2015 18:13
#676878
VTEC, that is one fine looking bike. A good candidate for bike of the month.
My Sportster gauge is oil filled and works good. Not as sexy as yours but good enough. I bought my Z1 when I was 21, it was a demo with 84 miles on it. $2300 in 75.
  • VTEC
16 Jun 2015 18:33 - 16 Jun 2015 18:37
#676884
swest wrote: VTEC, that is one fine looking bike. A good candidate for bike of the month.
Thanks Steve. Lot's of people that see my bike say they "use to have one". Guys like us still do.
Hey, did you notice the side emblems are from an older LTD? Never liked the little square LTD/1000 it came with.
KZ1000-K2
ZRX1100
XR400R
Last edit: 16 Jun 2015 18:37 by VTEC.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jun 2015 19:15
#676889
Yeah and some say they sold it to get a Harley. :lol: "Pride goith before a fall." Over the years they tried to shame me into submission. All I'd do is hit the start button, smile and take off with them standing there with their mouths open. I din't notice. At least it isn't squared off. The 80's were a lame time. IMO
  • VTEC
16 Jun 2015 19:28
#676890
Yeah, you have the classic, but I think I caught the last of an era. And I do love the "J" engine.
KZ1000-K2
ZRX1100
XR400R
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jun 2015 19:46
#676892
Foxy. :evil:
