1977 KZ 650 Off idle engine stumble when hot?
- rrsmsw9999
10 Jun 2015 05:07
Hello all,
Been riding this new to me antique a lot, about 750 miles the past two weeks. All routine maintenance completed. Bike starts, idles and runs great, but seems to have a stumble off idle after up to operating temp. I am going to move through the FSM idling procedure again. When warm it idles fine, at first movement of throttle to engage first gear, it stumbles and will die without jiggering. No problem on shifts and other gears. I am think air screws are too lean, but what say ye?
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- rrsmsw9999
Re: 1977 KZ 650 Off idle engine stumble when hot?
15 Jun 2015 18:23
Okay. Got the carbs fine synched with vacuum ghages. Idle is fantastic. Purrs like a kitten. It has a slight of idle stumble still. It is much better and won't die but it's there. All maintenance done not sure if this is it or if I have missed something. Good power in all gears. Any ideas?
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- missionkz
15 Jun 2015 22:23 - 15 Jun 2015 22:23Amazing how much better the engine idles when one or more carbs is not fighting the other ones!!rrsmsw9999 wrote: Okay. Got the carbs fine synched with vacuum ghages. Idle is fantastic. Purrs like a kitten. It has a slight of idle stumble still. It is much better and won't die but it's there. All maintenance done not sure if this is it or if I have missed something. Good power in all gears. Any ideas?
Stumbles off idle are most likely a temporary lean out. If all else is good, using pod air filters is usually the culprit.
If you do not have an accelerator pump carb setup, it will require a slightly richer idle mixture setting and possibly a richer pilot jet.
I just found that rolling the throttle on quickly, rather then snapping it WFO, pretty much removes the stumble.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 15 Jun 2015 22:23 by missionkz.
