Tank to Carbs.... Please Help!!
  • pocycle
  • pocycle's Avatar Topic Author
08 Jun 2015 18:18 - 08 Jun 2015 18:40
#675797
So I took apart my 1991 kz100p in order to paint it and my carbs to clean them. Shortly thereafter I found out I had to move before I had a chance to put everything back together...... Soooooo, I now have no idea where the hoses go from the Fuel tank to the petcock to the carbs etc...... If anyone coould maybe send a couple pics that would be great. I have a manual but its the Cylmar version (not the most helpful as far as pics go). Sincerest thanks, Signed Nube!!
Last edit: 08 Jun 2015 18:40 by pocycle. Reason: add pics
  • TexasKZ
  • TexasKZ's Avatar
Re: Tank to Carbs.... Please Help!!
08 Jun 2015 20:02
#675806
The petcock should have two barbs, one noticeably larger in diameter than the other. The large one is for fuel. The fuel hose should go from there to the fuel inlet which is low between carbs 2 & 3.
The smaller barb is for the vacuum that operates the petcock. A vacuum hose (smaller than the fuel hose) should go from there to the vacuum port on carb 2. As I recall, the vacuum port on each carb is near the carb holder and point upward at about 45 degrees. Two of them should have a rubber cap and the other is for the vacuum line from the air injection system on top of the engine.
The following user(s) said Thank You: pocycle
  • martin_csr
  • martin_csr's Avatar
09 Jun 2015 05:54 - 09 Jun 2015 06:12
#675842
In the 1st photo the round plastic thing is the fuel gauge cover ---the tubing is probably routed either to the airbox or behind the engine. I did not see a grommet in the airbox diagram, so it probably should go behind the engine, towards the ground --- forward of the swing arm and away from the chain & mufflers.
If the gasket on the fuel gauge leaks, the cover & tubing serve to direct fuel away from a hot engine.
Last edit: 09 Jun 2015 06:12 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
09 Jun 2015 14:53
#675915
Good catch, Martin. I forgot about that one.
  • martin_csr
09 Jun 2015 15:15
#675918
I was expecting there to be a canister do-dad system for the bike,
but I guess government vehicles don't have to worry about EPA regs. hee.
  • pocycle
09 Jun 2015 20:54
#675949
:) :) :) Super helpful Matin and Texas!!! Thank u, thank u!! I have the day off tomorrow so fingers crossed.....
