77 KZ650 carb synch ?
  • rrsmsw9999
  • rrsmsw9999's Avatar Topic Author
Re: 77 KZ650 carb synch ?
08 Jun 2015 05:08
#675693
What size where they? R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • ezrider714
  • ezrider714's Avatar
10 Jun 2015 20:17
#676101
Bowl screws are M4X16 16 total required
They can be purchased inexpensively at McMaster-Carr I use the S.S. ones to eliminate the possibility of rusting :blink:
EZ
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
  • rrsmsw9999
11 Jun 2015 21:58
#676258
Homemade vacuum gauge. 30$
R
Attachment p1-2.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
12 Jun 2015 01:00
#676263
rrsmsw9999 wrote: Homemade vacuum gauge. 30$
R
Links and/or details on this? Aweeso!e! I want one!!!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2015 05:57
#676273
What did you do about gauge flutter and where do you find four gauges, ball valves , fittings and tubing for $30? :huh:
  • rrsmsw9999
12 Jun 2015 07:02 - 12 Jun 2015 07:03
#676276
Okay here's the scoop.
www.amazon.com/gp/product/B00QXXIWGW?psc...i_detailpage_o00_s00
3.99 a piece
www.harborfreight.com/14-in-full-port-ball-valve-68254.html
$3.99 a piece
www.harborfreight.com/14-in-x-14-in-fema...-coupling-68200.html
$1.99 a piece
No link but the last fitting need is a maile 1/4in to 3/16 hose barb.
$1.79 a piece
Tubing was 3/16" @ 0.24$ a ft, 20 ft.
The bracket is simply a T-Shaped deck strap available at any hardware store, bent in a vise and drilled for the gauges. $2.79
So I did have a 50% off memorial day coupon for HarborFreight to be at 33$ with tax, but this is still at $42 full retail.
Gauge flutter. The ball valve can be closed nearly all the way and functions the same as a dampener. Alternately you could skip the valves and jam one of your old pilot jets in the top end of the hoses for the same effect. The valves completely eliminate flutter and still register active vacuum.
Again YMMV, also you can pay a bit more and get the thing fully assembled for 70$ + shipping online in a cpl of different places. I had fun doing this.
I will post video soon, as I will be replacing a broken adjuster bolt that I fudged up with the wrong screwdriver.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 12 Jun 2015 07:03 by rrsmsw9999.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2015 07:19
#676280
You're a better shopper than I am. B)
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2015 07:25 - 12 Jun 2015 07:27
#676281
I had a problem with the levels moving around and losing mercury if they fell over. I stuck a lag bolt in the breather and cured that problem 20 years ago.
They also had a nasty habit of the mercury being sucked up when revved. Not now.
Last edit: 12 Jun 2015 07:27 by SWest.
  • rrsmsw9999
13 Jun 2015 19:25 - 13 Jun 2015 19:26
#676460
Homemade vacuum gauge vid.
less than 40$ in parts. I think it works well.
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 13 Jun 2015 19:26 by rrsmsw9999.
  • ezrider714
13 Jun 2015 21:08
#676473
Just a thought, doesn't closing the ball valve to whatever degree required to address valve flutter lower the vacuum reading for that carb???
I really don't see how it couldn't
I have an old time one like Steve showed, however mine came with a check valve in each line to eliminate mercury being pulled up the lines to the carbs. Still works great after 30 yrs.
Dyna Coils
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Jun 2015 21:17
#676475
That's what I was thinking. Part of the reason to have them is to get a accurate vacuum reading. It shows the health of the engine.
  • rrsmsw9999
13 Jun 2015 21:49
#676481
There is no change in amount of vacuum. It's not psi. On these old vm24 carbs there is no need to use anything but a vacuum gauge and balance them within 2cm. When the flutter is going at full open valve it just pulsing the gauge. Same vacuum level. All the vacuum setups have a dampener inline. YMMV. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
