Bench setting float / fuel level
- CoreyClough
- GPz550 Addiction
Re: Bench setting float / fuel level
19 May 2015 04:54
Do it once, and do it right. What if what you are using other than gasoline, leaves a film, or deposit in the carb, then you have to rebuild them. Are these mechanical carbs, or vacuum slide carbs?
'85 GPz550(ZX550-A2)
- davido
19 May 2015 08:23
Go to your local bike shop and ask them nicely if you can do it there,youself. Maybe bung them a few quid/dollars,euros.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
19 May 2015 08:37Patton wrote: Odorless mineral spirits works well.
Can also use common household rubbing alcohol, after first determining the level it produces in a carb known to have a correct float height.
Pamper yourself by doing this while seated comfortably at the kitchen table (air conditioned, of course), on a fresh clean towel.
It saves time by using only one of the four float bowl screws to attach the bowl during successive attempts to achieve a perfectly tweeked tang position.
Yes -- one bowl screw is sufficient for the clear tube testing process.
In the unlikely event of a slight seepage potential, it doesn't affect the procedure or the results.
The following user(s) said Thank You: skooterbum4real
- missionkz
19 May 2015 12:01 - 19 May 2015 12:57Mine are the stock 26VM Mikuni mech slide carbs.CoreyClough wrote: Do it once, and do it right. What if what you are using other than gasoline, leaves a film, or deposit in the carb, then you have to rebuild them. Are these mechanical carbs, or vacuum slide carbs?
I can't say about the "what if's" with other stuff.
I used straight up oderless mineral spirits from the local hardware store.
I did put the carbs back together that night and installed the carbs two days later without doing anything other then connect the fuel tank/selector back to the carbs and filling them back with gas.
Disclosure:
I did check a couple weeks later to see how it was with real gas and it was a waste of my time based on the clear tube method.
Before rechecking, I had only put about 230 miles on the bike (since the firing the engine back up after the mineral spirits fuel level setting session)... but there has not been a single burp from the engine since then and have almost 600 miles on it now.
I'm not a chemical engineer but I don't think there will be any residue issue with the mineral spirits.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 19 May 2015 12:57 by missionkz.
- bountyhunter
19 May 2015 12:31Correct. I used to use it for soaking parts in to clean them. It doesn't evaporate and leave a sticky residue like gasoline does.missionkz wrote: I'm not a chemical engineer but I don't think there will be any residue issue with the mineral spirits.
The following user(s) said Thank You: Randombeat
- skooterbum4real
22 May 2015 23:50
Thanks for everyone's suggestions / advice !! Greatly appreciated !!
I ended up using my Denatured Alcohol to set the float height on my carbs. I got them mounted on the bike today, but have to get the carb to air cleaner box boots softened up, so I can get the air box connected, then will see if the bike will start.
This bike only has 8,500 miles on it, and has sat in a barn for over 15 years. I hope to get it to fire up tomorrow. It will put a big grin on my face if it does !!
I'll post back to let you know if Denatures Alcohol is a reliable liquid to use when setting the floats on our carbs. I hope it is ........
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
1976 KZ750 Twin
- Randombeat
- 0 to 100 real quick...
23 May 2015 00:02
Please keep us updated, it would be great if your substitution works! Don't dissapear without letting us know if the levels appear the same, once its running!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- BlackZ1R
- Kawasaki in my blood
23 May 2015 07:41
Alcohol works fine. Plenty close enough. Dang y'all, this isn't a nuclear reactor...... wait, Homer works at a nuclear plant. D'oh!
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
23 May 2015 07:48
That's frightening! :ohmy:
