Need help with my red neck build
- Richardb98
- Richardb98
Re: Need help with my red neck build
11 May 2015 19:37
That's a pretty good idea with the stockings. I'll try all of the things mentioned above tomorrow and I'll keep you guys updated.
11 May 2015 19:57
Have you tried Z1E for a K&L filter? They're $50 but are life time filters.
12 May 2015 06:00 - 13 May 2015 04:37If the airbox is missing, finding a complete replacement is going to be difficult.Richardb98 wrote: I need part 1-3. And yeah I'll try and scavenge up some foam tomorrow.
The airbox cap is even harder to find --- usually it's broken or missing.
Someone over at the kawasakimotorcycle.org site posted a how-to for making a 440 airbox from a RadioShack project box. There is a youtube video. Image text added by me.
Use ABS cement to weld the plastic together. regular pvc cement may not work.
ABS cement & adapter ring should be available at the hardware store or plumbing supply.
The air filter is probably 44 or 45mm. Or maybe 48mm. ???
PS: next time, instead of steel wool, use brillo pads. I have a photo somewhere. :laugh:
Last edit: 13 May 2015 04:37 by martin_csr.
The following user(s) said Thank You: Richardb98
12 May 2015 06:37
That's another reason PO's suck.
- Richardb98
12 May 2015 06:48
thanks for keeping this thred active guys! and martin that looks like a sweet set up and you can be sure ill look into that option. and i found an air box set up from an old guy in my neighborhood. its all janky but ill see if i can get everything sealed off. this just leaves me looking for the filter. he has the metal part of the filter but none of the original foam that was on it
12 May 2015 07:09 - 12 May 2015 08:27
The auto parts store might have sheet foam you can use to make your own.
I think you'd need to oil it with a motorcycle air filter oil.
When installing the airbox, treat the cap with care as the thing apparently tends to break.
Also, make sure the cap is installed properly --- the check is to pull up on the back of it gently --- it shouldn't move (don't break it).
Last edit: 12 May 2015 08:27 by martin_csr.
12 May 2015 07:16
You might look at dirt bike foam filters.
- Richardb98
12 May 2015 10:22
I ordered a sheet of element from eBay so let's see how this works out. And I'm not sure what you mean by pulling on the cap? I'll include a pic of my build so far just for giggles
- Richardb98
12 May 2015 10:36
Another quick update, so after taking it around the block yesterday a couple times it wouldn't start so I put it up for the night. Well so I just pulled out the right plug and it was super fouled to where it wasn't even getting spark after I cleaned it. So I started getting worried maybe it was something bigger but I threw in the old plug and that was sparking but I couldn't get it to run because I had to throw the battery on the charger
12 May 2015 10:41 - 12 May 2015 10:42
To check that the airbox cap is properly secured, gently pull up on the back of the cap. I think it's supposed to fit into some grooves on the airbox --- fit the cap in place then attach the screws. If done wrong, you'll have a big vacuum leak.
I think you'd need to oil the air filter with a motorcycle air filter oil.
Last edit: 12 May 2015 10:42 by martin_csr.
12 May 2015 14:01
At least you didn't hack off the tail end. :woohoo: You can put a good seat on it. :whistle:
