KZ 440 Jetting
  • Mat429
  • Mat429's Avatar Topic Author
KZ 440 Jetting
09 May 2015 22:09
#671317
I have an 81 kz 440 with Pods and mufflers cut off. At low rpms its very very blubbery but as soon as you get to mid throttle it runs great. I shimmed the needle to move it up a bit. The fuel air screws are out about 4 1/2 turns. Should i get bigger pilot jets? Was thinking the mains were good because it runs so well from mid to top. Tryin to get some advice so i can stop taking the carbs apart…help me!
- Mat
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: KZ 440 Jetting
10 May 2015 06:18
#671347
Do a search on KZ440 jetting.
1) cut off exhaust just makes noise, there is NO performance advantage.
Just the opposite happens, they reduce it.
2) the filters you are using could be all wrong, do they block the air bleeds?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Mat429
Re: KZ 440 Jetting
11 May 2015 14:46
#671575
i ended up getting it by doing some tinkering. Went up a few sizes on the main and a little bit on the Pilot and it runs great.
  • Richardb98
  • Richardb98's Avatar
Re: KZ 440 Jetting
11 May 2015 15:12
#671581
Hey mat I have a 440 too and I was wondering if you could tell me where the fuel mixture screw is? It's probably really obvious but for some reason I can't find it. Thanks
  • Mat429
Re: KZ 440 Jetting
11 May 2015 20:12
#671691
Richard mine are on the top of the carbs toward the front of the bike so you have to have a really small flathead to fit under the tank to adjust them. I also know some of them have a little plug covering them and you have to drill through it to get to them.
The following user(s) said Thank You: Richardb98
  • undiablo
  • undiablo's Avatar
Re: KZ 440 Jetting
13 May 2015 16:02
#671974
Mat429: do you mean you manage to get bigger pilots? could you tell us where?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
  • JR
  • JR's Avatar
Re: KZ 440 Jetting
13 May 2015 16:10
#671976
undiablo wrote: Mat429: do you mean you manage to get bigger pilots? could you tell us where?
+1
Please tell.
  • Mat429
Re: KZ 440 Jetting
13 May 2015 19:16
#672001
I got micro drill bits and drilled them out just a little bit.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ 440 Jetting
13 May 2015 21:33
#672015
That's what I'm doing to find that "sweet spot". If you make a mistake you can solder them and start over. Best to have a spare set to play with.
  • JR
  • JR's Avatar
Re: KZ 440 Jetting
14 May 2015 05:02 - 14 May 2015 05:06
#672030
Mat429 wrote: I got micro drill bits and drilled them out just a little bit.
thanks for the info. I was hoping you had found a source. I won't risk drilling though.
It would be nice to try a bigger size pilot but if I screwed up drilling then dead in the water. I can live with what I have
Keihin pilots for the CV34 just don't seem to be available. Darn!
Last edit: 14 May 2015 05:06 by JR.
Re: KZ 440 Jetting
14 May 2015 06:46
#672041
.... I won't risk drilling though.
Smart man! Ed
  • undiablo
  • undiablo's Avatar
Re: KZ 440 Jetting
14 May 2015 07:57
#672053
I wonder if anyone with a good micro CNC lather could make them...
