28mm pumper help
  • tbird
  • tbird's Avatar Topic Author
28mm pumper help
08 May 2015 18:35
#671184
Hi new member here looking for help
helping friend rebuild set of 28mm pumper carb , with both pumps , carbs came some what a part , like to know the jets size , and in the bowls are a weight and round steel ball under a c-clip , do all 4 bowls get these , and any other info on these carb will be helpful
bike is a 79kz 1000 stock motor ,pods , 4 to 1 exhaust ,
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 28mm pumper help
08 May 2015 19:56
#671194
It's hard to understand what you just said about the bowls. Only one bowl has the pump. You say it has two? The ball bearing is a check valve/ball. If the carbs are flooding, it's the diaphragm/'s that is the culprit. Each carb has a jet that is controlled by the pump/'s. If it leaks, gas will be sucked into the carbs uncontrolled.
  • tbird
08 May 2015 21:34
#671208
hey Steve . thanks for replay , yes has 2 pumps one square has rod on it and a triangle one on bottom ,
and do all 4 carbs bowls get a check ball ?
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • JimB
  • JimB's Avatar
09 May 2015 05:04
#671227
Yes,...all 4 bowls get a check ball and c clip to keep it in.
For jets,...a good starting point would be 17.5 pilots and 117.5 mains.
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
09 May 2015 05:14 - 09 May 2015 05:15
#671228
According to the parts diagram on Kawasaki.com (see www.kawasaki.com/Parts/PartsDiagram/144219/1979/KZ1000-A3 ) all 4 carbs have the check valves. Ed
Attachment 00003a-25.jpg not found
Last edit: 09 May 2015 05:15 by 650ed.
  • martin_csr
  • martin_csr's Avatar
09 May 2015 08:19 - 09 May 2015 08:26
#671241
tbird wrote: hey Steve . thanks for replay , yes has 2 pumps one square has rod on it and a triangle one on bottom ,
It sounds like there's one accelerator pump --- two would be unusual.
The triangular setup is a vacuum sensor --- I think it acts to shut off fuel to the accelerator pump when the engine stops. The thing is disabled at the factory on some models (such as my 81 650).
Last edit: 09 May 2015 08:26 by martin_csr.
  • tbird
09 May 2015 10:19
#671247
Hi Thanks Guys , making little more since now , some great info, , if you come up with any thing else let me know ,
  • jeff80kz1000e2
  • jeff80kz1000e2's Avatar
13 May 2015 10:55
#671945
+1 on the triangular vacuum sensor, my 80kz1000st has it but is dis abled as well per my manual and physical check
  • tbird
19 May 2015 23:23
#672817
hi on these carb what size fuel line are you using from float bowls to float bowl , ?? 1/8 to small ,1/4/ to big .
he was wanting the blue fuel line , any one know of any thing that will work ?
  • zed1015
  • zed1015's Avatar
19 May 2015 23:49
#672818
Are you sure they are 28mm pumpers.
Only the 26mm 's had both diaphragms fitted.
The 28's had the triangular one blanked off.
  • martin_csr
20 May 2015 05:14 - 20 May 2015 05:18
#672834
tbird wrote: hi on these carb what size fuel line are you using from float bowls to float bowl , ?? 1/8 to small ,1/4/ to big .
3/16 seems like the logical size to try. Metric --- probably 5mm [(3/16) x 25.4 = 4.8mm]
And all 4 bowls should have a ball, weight & clip, and on the pump nozzles at the carb body gasket surface each nozzle should have an o-ring.
Last edit: 20 May 2015 05:18 by martin_csr.
The following user(s) said Thank You: tbird
