1981 kz 550c extended cables?
- AKBOBBER
07 May 2015 11:28
I have a 81 kz550c that I am hard tailing and putting 12" apes on and would like to know if anyone has a line on extended cables that will work or what someone else might have done already.
any info would be greatly appreciated.
thank you
thank you
Brandon D.
- Tyrell Corp
Re: 1981 kz 550c extended cables?
07 May 2015 11:38
Motion Pro CA make custom cables.
Hardtial with ape hangers , cool, very 70's.
07 May 2015 13:52
Be sure to note the amount of slack in the stock cables. A tad more slack is okay, but with less, the cables might not fit. With a mid-cable barrel adjuster, you can probably go an extra 1/4" of slack. When I got lower handlebars, I ordered 750E cables, but the open cable wouldn't work because it had less slack than my stock cable. doh.
