ZX7 1991 - Pilot Screws ?
- coolio2015
30 Apr 2015 17:00 - 30 Apr 2015 17:47
Hi,
I'm cleaning my carbs and have removed the pilot screws...maybe also called the slow jet...
I'm re-installing but need to know what order the washer and rubber gasket go?
Is it:
Spring, metal washer, rubber gasket?
or
Spring, rubber gasket, metal washer?
The manual doesn't show a clear picture...of the sequence...
I'm going to install them like this: spring, washer, rubber gasket and hope it's correct.
Thanks,
Is it:
or
Thanks,
Last edit: 30 Apr 2015 17:47 by coolio2015. Reason: trying to make it more clear...
- StreetfighterKz
Re: Re:ZX7 1991 - Pilot Screws ?
30 Apr 2015 17:56
The washer goes between the spring and rubber o-ring. Just remember to lightly seat the screw before turning it back out to the proper turn number. Don't crank it down.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: coolio2015
- coolio2015
