- Thank you received: 3
Mikuni 29mm smothe bores on an 82 GPZ 750
- Jrider
27 Apr 2015 10:55 #669763
by Jrider
1982 Kawasaki KZ 750 R , Stock
2007 Harley Davidson Police Electraglide
Mikuni 29mm smothe bores on an 82 GPZ 750 was created by Jrider
Will old school MIkuni 29mm smooth bores work as a replacement for the BS34s on a GPZ? I want to run K&N pods and the BS34s are not pod friendly. I hear that the smooth bores are easy to jet for pods. Is this true and will they be a performance upgrade from my stock cards? Fire away!
- zukdave
- Thank you received: 229
27 Apr 2015 16:08 - 27 Apr 2015 16:12 #669799
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Mikuni 29mm smothe bores on an 82 GPZ 750
I think you'd be better off with VM28's.if not VM26's.unless
your building a hot rodded motor with big bore kit ported head and big cams.
On my ZX750A1 motor which has a better flowing head and bigger cams then
your motor idle and just off idle is a bitch to tune.
Sudco lists a 25 pilot and a 125 main as a starting point for jetting
with VM29's on a 750 size motor due to a weak idle signal caused
by slow air flow.
by slow air flow.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 27 Apr 2015 16:12 by zukdave.
- les holt
- Thank you received: 288
27 Apr 2015 17:59 #669807
by les holt
Replied by les holt on topic Mikuni 29mm smothe bores on an 82 GPZ 750
Those 29's are just fine if not better than fine on a 750!!!
Les Holt
Les Holt
- Thank you received: 2841
27 Apr 2015 18:20 #669810
by Nessism
Replied by Nessism on topic Mikuni 29mm smothe bores on an 82 GPZ 750
Without getting into what's better or worse, I know that a Dynojet kit for your BS34 CV carbs will allow the bike to run nicely using pods and a header.
