Leaky petcock -- how does vacuum leave petcock?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Leaky petcock -- how does vacuum leave petcock?
07 May 2015 05:53
#670977
I've never seen a check valve between the carb and the petcock.
  • drumstyx
  • drumstyx's Avatar Topic Author
07 May 2015 06:15
#670981
Hmm, well then, I suppose I'll try clearing out that passage. At worst I'll need a new back plate and in the meantime it'd turn into a non-vacuum petcock.
1984 KZ750L (L4)
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 May 2015 06:27
#670984
If the diaphragm has a leak, gas will get into the intake port. You can block off both passages and run on prime. I'd buy a new one.
  • drumstyx
08 May 2015 09:31
#671125
Just an update on tracking this problem down. It turns out there is a check valve that's supposed to be there. It seems, according to the KZ750 'bible', that it's supposed to allow neutral pressure back in, just not positive pressure. I'm thinking that's worn out, and buying the whole back piece, since I can't buy it separately.
1984 KZ750L (L4)
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 May 2015 10:57
#671129
:huh:
  • martin_csr
  • martin_csr's Avatar
08 May 2015 11:44 - 08 May 2015 17:02
#671137
The check valve is just a little ball or BB, so air flow thru the square vac plate is uni-directional or one way.
Remove the square vacuum plate, attach tubing to the vac port, then suck on the tubing --- you should be able to suck air. Then try to blow air thru the tubing --- the BB should block the flow of air. I would go ahead & clean the thing, such as spraying carb cleaner thru the little holes.
Then clean & inspect the rest of the petcock. If no pitting or wear scratches or anything, get a rebuild kit. Some guys prefer oem. I installed a K&L kit (made in Japan).
Last edit: 08 May 2015 17:02 by martin_csr.
  • LuckyLucOnBass
  • LuckyLucOnBass's Avatar
08 May 2015 12:32
#671145
My 550 had a vacuum petcock. I replaced it with a manual On/Off/Reserve petcock. I think I paid less than $15 for it.
bass player, bike rider, hockey fan.
1983 KZ550 M1
  • drumstyx
08 May 2015 12:52
#671150
The check valve definitely should not hold a perfect vacuum in the chamber. It needs to equalize somehow.
I believe it's a plastic disc in this case, but I'll have a look today.
1984 KZ750L (L4)
  • martin_csr
08 May 2015 16:58 - 08 May 2015 17:00
#671177
It's a plastic disk. never bothered to check before. no need. :)
If air flows one way, then the problem isn't the vac cover.
The diaphragm can look good but still be bad. After cleaning the petcock body n stuff, I buffed the mating surfaces w brass wool. steel wool would work.
Last edit: 08 May 2015 17:00 by martin_csr.
  • RonKZ650
  • RonKZ650's Avatar
08 May 2015 20:48
#671204
I had to go out and take one apart to see this check ball deal. Sure enough, there is one in the vacuum chamber inlet. That being true though, I would look elsewhere for the problem.
  • ezrider714
  • ezrider714's Avatar
10 May 2015 00:26
#671330
The real problem is having a vacuum operated petcock, :blink: find a manual to swap it out with, problem solved for years..... :woohoo:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
10 May 2015 06:36
#671351
ezrider714 wrote: The real problem is having a vacuum operated petcock, :blink: find a manual to swap it out with, problem solved for years..... :woohoo:
+1 My '77 KZ650-C1 came with the manual petcock and I would never swap it for a vacuum one; they simply have too many problems. Ed
