KZ305CSR idle mixture screws and adjustment
  • happyhunter
  • happyhunter's Avatar Topic Author
09 Apr 2015 09:29
#667261
I have had starting issues with this bike since I bought it last year. Very unreliable. I have done a lot to it last summer:
Derust tank
Clean carbs
New points and condenser
new plugs
new intake manifolds
new aircleaner
I continue to have problems. The plugs get fouled in about 100 miles and it gets hard to start. If I clean the plugs or just run it a couple miles without the airfilter it seems to go good for a while.
One area that I notice and want to address is adjusting idle with the mix screws on the side of the carb. One side (I forget which side) turning the screw does affect how it idles. On the other side turning the screw has no affect on the idle. The screws look the same. I pulled them apart the other day. I know there is to be a flat washer and an O ring in each carb in front of the mix screw. Neither side had a washer. Both O rings were torn. Will this affect the idle or is the O ring just to keep the screw from turning???
I want to try swapping the screws from side to side to see if that changes which carb can be idle adjusted. But right now I can't even get it started.
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: KZ305CSR idle mixture screws and adjustment
09 Apr 2015 12:06
#667280
Not sure if this will help you or not but here are some pages from FSM
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Rustyhama
  • Rustyhama's Avatar
Re: Re:KZ305CSR idle mixture screws and adjustment
09 Apr 2015 12:07 - 09 Apr 2015 12:29
#667281
Hi, I have one of those too. Sounds like you need school up on carb function and tuning.
www.factorypro.com/tech/tech_tuning_proc...igh_rpm_engines.html
xlforum.net/vbportal/forums/showthread.php?t=31262
It's very important to get the mixture screws right and very easy. If you're fouling plugs you must be too rich. Remember our mixture screws are on the fuel side of the carb so winding them out makes it richer. The stock setting is 2 and 1/2 turns out from LIGHTLY seated. Start from there and see how she goes.
Hama
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
Last edit: 09 Apr 2015 12:29 by Rustyhama.
  • SweetwoodSUP
  • SweetwoodSUP's Avatar
09 Apr 2015 16:19
#667312
I'm wondering if your plugs are fouled from being too rich or if they are oil fouled. Can you post a pic of a fouled plug? It must be smoking. Is it blue smoke?
'79 LTD 1000
'84 Ninja 900 (Sold, What was I thinking!)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
