34 mm mukuni vacume secondaries
- harleeblue
05 Apr 2015 17:21 - 05 Apr 2015 17:32
how do I know what year carbs will fit on my bike ? I know the earlier kz took manuel sliders.can I use anything newer of kz s as long as there 34mm vacuum sliders.for example can I use kz1100 carbs and just change my jets and needles. or do I need 1000j carbs .can I use 1990 kz 1000 police carbs. where do I find this info ?my dino jet kit required me to drill out the intake side air blead.the result I got was way to lean. idelcircuit and uping the pilot jet did not help idel.way to lean the pipes glow red even when I turn the air mixture screws way out or in!!
bradley frantz
Last edit: 05 Apr 2015 17:32 by harleeblue. Reason: lots of typo lol
- azman857
Re: 34 mm mukuni vacume secondaries
05 Apr 2015 17:29
What bike do you have?
- harleeblue
- 78kzturbo
05 Apr 2015 17:36 - 05 Apr 2015 17:37
kz1100 carbs will work on your bike also police models will work. gs1100 carbs will also work and 36mm gs1150 . All these carbs have the same spacing. If you use gs carbs you will need to use the throttle cable bracket from your old carbs. Dave
Last edit: 05 Apr 2015 17:37 by 78kzturbo.
- harleeblue
- floivanus
05 Apr 2015 18:22
Be aware the gs1000 carbs have different bowls (no, really not a joke choke pickup tube in slightly different spot) and quite different air bleeds etc. Not to mention the needle/seat are different with the seat pressed in and o-ringed vs. the screw in gasketed kz type.
I just went thru the ones on my gs1000 and have a bo of kz1000 bs34s that had better float bowls and had to use the gs ones
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- baldy110
05 Apr 2015 18:58
You can also use the VM 26's off earlier KZ1000 and Kz900.
