81 kz750e dynojet question
  • jcollins748891
  • jcollins748891's Avatar Topic Author
10 Mar 2015 09:33
#663971
Hey guys. Just started working on my kz again. I got the dynojet kit for it. I'm installing stage three. My issue is that in the instructions, it tells me to drill the hole on the slider. And the instructions only shows one hole. My slider has two holes. I have the keihen carbs. I believe the diagram in the instructions is for the mikuni. And yes I have the right jet kit for my carbs. I can post pics later. I'm currently working right now. But any ideas? Do I drill both? Or leave them alone? Drill one? Thanks!
  • baldy110
  • baldy110's Avatar
Re: 81 kz750e dynojet question
10 Mar 2015 11:02
#663979
You drill the hole at the bottom of the slide not the one on the side of it.
  • jcollins748891
10 Mar 2015 13:01
#663987
Ik that. My slide has two on the bottom. Here are the pics.
  • jcollins748891
10 Mar 2015 13:23
#663988
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:81 kz750e dynojet question
10 Mar 2015 13:42
#663990
This may be a wild question but are the carbs you have the correct carbs for the bike? Is unlikely but possible someone swapped them in the last 34 years.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • jcollins748891
10 Mar 2015 13:52
#663991
They are original to my knowlage. The are keihin . from what I've read 81-83 kz have keihin and 84-87 I belive have mikuni.
  • jcollins748891
10 Mar 2015 13:55 - 10 Mar 2015 13:58
#663992
And the stock carbs I look up for the bike online are the same ones I have..so :dry: and from what I see online the mikuni carbs have the slider shown in the diagram. I think it may be a miss print? But any who I still need to know if I need to still drill them out and to what bit size
Last edit: 10 Mar 2015 13:58 by jcollins748891.
  • Nebr_Rex
  • Nebr_Rex's Avatar
10 Mar 2015 19:25
#664029
Drill both, I just finished doing mine. The difference in size is minimal.
I'm waiting for a new throttle cable to complete the job.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: jcollins748891
  • jcollins748891
11 Mar 2015 06:19
#664069
Nebr_Rex wrote: Drill both, I just finished doing mine. The difference in size is minimal.
Okay. Thanks!
