Carbs
  • gremlin497
  • gremlin497's Avatar Topic Author
Carbs
07 Mar 2015 06:41
#663675
Looking to buy new set of carbs. Currently have 77 KZ 1000 with 1075 piston. Heads not ported and have stock cams.
Looking for advise on what carbs to get to be able to ride now, with head work and new cams later. Any input would be greatly appericated. Also have set of 29 Smoothbore carbs for sale. Will post pictures later of carbs for sale.
1977 KZ 1075 (FBG), 29 Smoothbores V&H Mega
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • TexasKZ
  • TexasKZ's Avatar
Re: Carbs
07 Mar 2015 08:05
#663686
swest wrote: Why not use the 29"s?
The 29s should work brilliantly on a mild 1075.
  • floivanus
  • floivanus's Avatar
Re: Carbs
07 Mar 2015 09:30
#663690
Vm28's should be basically as good as the 29s, (the newer non-z1 type) they are comparable to the 29s
But, if you already have the 29s and want to "get running" you could use those
Past; 78 kz1000, 83 kz550
Andrew
  • gremlin497
Re: Carbs
07 Mar 2015 10:08
#663691
I wanted to run the 29's, but really have hard time with getting float height correct and not running smoothly. I brought the clear tube for getting float height correct, but just still having problems.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carbs
07 Mar 2015 12:53
#663704
It's worth the effort. My 33's are too big. The engine just can't take that much juice.
Re: Carbs
07 Mar 2015 14:46
#663705
gremlin497 wrote: I wanted to run the 29's, but really have hard time with getting float height correct and not running smoothly. I brought the clear tube for getting float height correct, but just still having problems.
What problems?
Should be able to achieve correct fuel level via float tang adjustment.
Good Fortune! :)
  • gremlin497
Re: Carbs
14 Mar 2015 14:31
#664419
Attachment image.jpg not found
  • gremlin497
Re: Carbs
14 Mar 2015 14:44
#664423
So I want to get new carbs for my bike. Need to know the best and most reliable place that sells new carbs, with no problems. I like the idea of the 29 CR Specials. Would like to get the RS34, but with no head work (ie: cams or porting), just looking for advise from some of you out there. Thx in advance.
Also have those 29 Smoothbore for sell.
  • missionkz
  • missionkz's Avatar
Re: Carbs
14 Mar 2015 14:56
#664427
Hope you have a BIG bank account.... LOL
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • gremlin497
Re: Carbs
14 Mar 2015 15:30
#664435
Nothing. Just having issues getting them tuned. Just want to get new set of carbs.
