1995 KZ1000P Full Throttle Bog
  • iamspugeddy
  • iamspugeddy's Avatar Topic Author
27 Feb 2015 13:23
#662901
The throttle is responsive and strong until it's nearly at full throttle, then it feels almost like it's missing and it won't go faster than about 85 mph. I've tried replacing the ignition and plugs, but it didn't fix anything. I've heard it could be a jet issue. Suggestions? Thanks.
Re: 1995 KZ1000P Full Throttle Bog
27 Feb 2015 20:02
#662943
iamspugeddy wrote: The throttle is responsive and strong until it's nearly at full throttle, then it feels almost like it's missing and it won't go faster than about 85 mph. I've tried replacing the ignition and plugs, but it didn't fix anything. I've heard it could be a jet issue. Suggestions? Thanks.
Hello, iamspugeddy, and WELCOME to KZr! :cheer:
Perhaps main jets are too large, or maybe loose.
Is the air filter dirty or otherwise obstructed?
What is spark quality when viewed with plugs removed?
Supposed to be fat blue sparks, and not thin orange sparks.
Good Fortune! :)
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
27 Feb 2015 20:12
#662944
See:
www.kzrider.com/forum/2-engine/596501-81...deas?start=20#661755
1982 KZ1100-A2
The following user(s) said Thank You: HBKwaka
27 Feb 2015 20:26
#662945
Does the bike have the stock air box and air filter? Ed
  • iamspugeddy
27 Feb 2015 23:00
#662949
Thanks for the replies. I'm fairly certain the bike is all stock, so I'll start with the filter and work my way towards the heavier work from there. I appreciate the help and I'll update as I go.
  • HBKwaka
  • HBKwaka's Avatar
28 Feb 2015 08:19 - 28 Feb 2015 08:22
#662968
Attachment IMG_8437.jpg not found
Epoxy over the hole and rev limitations are off....ride safe
Thread about it here:
Last edit: 28 Feb 2015 08:22 by HBKwaka.
  • iamspugeddy
28 Feb 2015 10:46
#662981
I'll be checking those out when I get home today. If that's the only problem, you will all be considered my heroes.
  • HBKwaka
  • HBKwaka's Avatar
28 Feb 2015 10:58
#662987
iamspugeddy wrote: I'll be checking those out when I get home today. If that's the only problem, you will all be considered my heroes.
Back in the day I always wondered why the motor coppers wouldn't go faster than 80+ chasing me on my VFR700...I even out ran a helo once...
