ID of Intake manifold for CV Carbs
- kzspartan
17 Jan 2015 14:19
I am looking to install ZX6 Carbs (32mm) on my KZ. Looking for information and then intake manifolds to fit.
Looking to reduce weight 13 pounds stock to 4 pounds ZX.
What is the ID of CV Mikuni Carb manifolds. Looking for 1981 and up, Maybe GPZ if anyone knows.
I have a 1980 KZ1000.
Thanks
Thanks
- floivanus
Re: ID of Intake manifold for CV Carbs
17 Jan 2015 16:01
The 81 and up cv carbs are 34 but what concerns you is the carbs OD; if it matches the zx carbs you are good to go (after re-racking or respacing of course)
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- kzspartan
17 Jan 2015 20:13 - 17 Jan 2015 20:29
Yes, the OD of the ZX6 Carbs are 37.9mm. If anyone can tell me the OD of the 34Cv carbs, that would be great.
Re-racking and getting the enriching circuit rail spaced is very time consuming. Seeing winter is here, it makes for a good indoor Garage project while listening to football games.
Last edit: 17 Jan 2015 20:29 by kzspartan.
- kzspartan
20 Jan 2015 18:53
I got the answer. 40mm I.D. for 34mmCV Carbs
