Can't remove jet needle
  • Bama704
  • Bama704's Avatar Topic Author
17 Jan 2015 09:21
#658895
I took my carbs apart once again because the bike would not start without starting fluid and I had to replace my main jets anyways, also I did have fuel in each of the bowls. I was going to replace my jet needles with new ones but ran into a problem after I replaced the first jet needle. The second third and fourth jet needles would not come out because the screws inside the throttle valve are stripped from the previous owner. Is there any way to remove these screws?
I don't want to have to buy new throttle valves, also I wanted to change the clip position from 4 to 3. At least I think they are all at the fourth position based off of the only one I was able to remove.
Any advice and or suggestions is appreciated.
1977 KZ900
Carbs are late model 1975 28mm
  • bountyhunter
  • bountyhunter's Avatar
Re: Can't remove jet needle
17 Jan 2015 12:25 - 17 Jan 2015 12:26
#658906
IMHO, it would be very unlikely that needles would cause the hard starting you describe since the carbs start with the throttles closed and the slides all the way down. The bike starts on the very rich "chocke" system which isn't actually a choke but a big jet that dumps a lot of gas in. It also runs on the pilot circuit since the throttle is closed so both choke and pilot systems are suspect when there's hard starting, the choke is probably not working right.
Last edit: 17 Jan 2015 12:26 by bountyhunter.
  • Bama704
17 Jan 2015 14:05
#658912
I agree that the needles would have no impact on it starting, but since I was taking the carbs apart to clean I figured why not change them out and the clip position.
1977 KZ900
  • rokit_armor
  • rokit_armor's Avatar
17 Jan 2015 14:34
#658914
I had the same problem. I was able to carefully drill the head of the screw off, then use a smaller bit to drill the body of the screw out. Just be careful not to strip the threads. I found if I drilled the head off just right, when I went to drill the body out, it just screwed itself through.
  • zukdave
  • zukdave's Avatar
17 Jan 2015 18:31
#658928
Use a left hand drill bit real slow and it should bite the screw
and turn it out.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
The following user(s) said Thank You: PLUMMEN
  • Bama704
17 Jan 2015 22:16
#658944
I don't know what a left handed drill bit is, how is this any different from a normal drill bit?
And rokit, did you use something comparable to a dremmel tool? And you drilled out the center bit? I am more of a visual leaner, do you have any Pictures by any chance.
1977 KZ900
  • Special KK
  • Special KK's Avatar
18 Jan 2015 02:42 - 18 Jan 2015 02:43
#658954
A left handed drill bit is basically the opposite cutting thread to a normal right facing drill bit, personally ive never tried this method but it looks a lot less faffing about than doing it with the stud extractor, this youtube video is a good visual guide:
2008 Aprilia Shiver SL750
1983 Kawasaki KZ750 LTD H4 Four cylinder
Previous bikes:
1999 Honda CBR 600 fx
1992 Kawasaki Zephyr 550b
1990 Honda CG 125
"All work and no play makes jack a dull boy"
Last edit: 18 Jan 2015 02:43 by Special KK.
  • zukdave
  • zukdave's Avatar
18 Jan 2015 06:42
#658970
Thank's SKK.
I bet he was thinkin I was being a smart a$$
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Special KK
18 Jan 2015 11:22
#658988
Haha got to admit it does sound like a Tartan Paint kind of thing ;)
Previous bikes:
1990 Honda CG 125
