Stock air/fuel mixture turns kz550
- daren1093251
12 Jan 2015 15:36
I know this is a very hard question to ask, but I just need a pointed in the right decision. I got a 1984 kz550 and when i got it the carbs were already apart, so i just out theair/fuel screw 1.5 turns out to start. The bike runs idle, roughly. If somebody knows approx. how many turns out for it to run a bit better for now. Thanks
If you ain't first ; You're last
Current bikes :
2013 Kawasaki KLX250s
1984 Kawasaki KZ550 LTD (Project!)
1985 Honda Aero 85 (Rebuilding!)
Current bikes :
- JR
Re: Stock air/fuel mixture turns kz550
12 Jan 2015 16:24 - 12 Jan 2015 16:26
loudhvx our resident 550 expert and electrical guru has a ton of 550 information in his signature. Do a search here for any posts he has made and check his signature for the 550 stuff
Here is one link from his signature on 550 carbs and which may help answer your question - scroll down to see the table
home.comcast.net/~loudgpz/GPZweb/TK22mainPage/TK22mainPage.html
Last edit: 12 Jan 2015 16:26 by JR.
- loudhvx
12 Jan 2015 17:55 - 12 Jan 2015 18:00
Unfortunately, my carb site won't help with his bike. He uses TK26 CV carbs. I only have info on the TK22 slide carbs.
The manuals linked in my signature might help a little, but I don't have factory manuals for the shaft drive 550's. The third party manual might have some info, and he may get some help from the manual which covers the 82-83 KZ550H gpz models, as they used a variant of the TK26 CV carbs.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 12 Jan 2015 18:00 by loudhvx.
- GPzEric
17 Jan 2015 10:58
Get it running at full temperature, then slowly adjust the mixture to where it idles best/fastest, then set the idle speed.
If the mixture screws don't do anything (common on old bikes) start looking for the vacuum leak / clog.
Have a KZ day !
Have a KZ day !
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- loudhvx
17 Jan 2015 12:29
As long as the screws do affect the idle, the preferred method is the lean-drop method. That's where you lean it out until the idle speed drops, then turn the screws back to just barely recover the RPMs.
1981 KZ550 D1 gpz.
Other links.
Other links.
