carb issues?
- Special KK
Re: carb issues?
09 Mar 2015 05:58
Yeah those are the ones most be the same.
And yeah pretty damn slim I would think unfortunately!
2008 Aprilia Shiver SL750
1983 Kawasaki KZ750 LTD H4 Four cylinder
Previous bikes:
1999 Honda CBR 600 fx
1992 Kawasaki Zephyr 550b
1990 Honda CG 125
"All work and no play makes jack a dull boy"
Previous bikes:
1990 Honda CG 125
- Zephyrrider
Re: carb issues?
09 Mar 2015 05:59
Did you put the rubber caps on and can you take them off and have a look ?
Mick
1994 ZR750 Zephyr C4.
- Zephyrrider
Re: carb issues?
09 Mar 2015 06:01
Have you got a pic of how the caps/vacumn line on top of carbs is set up at the moment ?
Mick
Re: carb issues?
09 Mar 2015 06:04
Some carbs have a vacuum nipple that may be confused with one of the two vent nipples.
Be sure the vac hose from petcock isn't attached to a vent nipple.
Except for the vacuum nipple being used to supply vacuum to the petcock, all other vac nipples should be capped/plugged.
Assure that both of the two vent nipples exit to open air.
- Zephyrrider
Re: carb issues?
09 Mar 2015 06:16 - 09 Mar 2015 06:18
Not on mine Patton - long vacumn line joins 1 and 4 another short line from 2 to 3 with "T join" between them which then runs to fuel tap
SKK not a great pic but you get the idea mate.
Only other nipples are float bowl drains.
Attachment CV32s.jpg not found
Mick
Last edit: 09 Mar 2015 06:18 by Zephyrrider.
The following user(s) said Thank You: Patton
- Special KK
Re: carb issues?
09 Mar 2015 06:22
Yeah those carbs look very similar to mine, that's where my vacuum tube vents to those nipples. Mine is only on one of the nipples though which I think is correct. Where do your 1 & 4 go to? Ram air system perhaps?
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
- Zephyrrider
Re: carb issues?
09 Mar 2015 06:40
Would you be able to take a pic of yours ? 1 and 4 just balance each other within carbs
have you got any extra vacumn line ?
Mick
- Zephyrrider
Re: carb issues?
09 Mar 2015 06:49 - 09 Mar 2015 06:51
If you havn't tried hooking up vacumn lines same as mine it would be well worth a go.
this is how mine came out and had it 21 years - never had that fuel starvation problem like your bike.
Same nipples are where you would put lines to sync carbs.
Mick
Last edit: 09 Mar 2015 06:51 by Zephyrrider.
- Special KK
Re: carb issues?
09 Mar 2015 06:51
Yea can do I've got the spare set so I can take a pic of them and post it up, I'm at work atm though so prob tomo. I've got some vacuum line I might have a play around with it, swap it out etc.
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
- Zephyrrider
Re: carb issues?
09 Mar 2015 06:58
Can you setup your spares for pic with vacumn line, caps same as on your bike - will check out your post tomorrow night.
Mick
- Special KK
Re: carb issues?
09 Mar 2015 06:58Zephyrrider wrote: If you havn't tried hooking up vacumn lines same as mine it would be well worth a go.
Ok mate its definitely worth a go, perhaps there's not enough vacuum getting through with just the one hose and where I took off the exhaust recycle system so can't hurt to play around with it.
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
- Special KK
Re: carb issues?
09 Mar 2015 06:59Zephyrrider wrote: Can you setup your spares for pic with vacumn line, caps same as on your bike - will check out your post tomorrow night.
Yeah no problems mate, cheers
Previous bikes:
1990 Honda CG 125
Previous bikes:
1990 Honda CG 125
