kz1100 ltd tubes on back of carbs
- rarewolf
16 Dec 2014 17:38
These tubes (or what used to be tubes) are jutting off the back of the carb assembly on my 83 kz1100 ltd. What are they for?
Re: kz1100 ltd tubes on back of carbs
17 Dec 2014 03:15
Could be from carb vent nipples that correctly exit to open air.
17 Dec 2014 05:01
Could be vacuum ports for operating the Clean Air system and the petcock, in which case a couple of them need to be connected to those items and the others capped.
A factory service manual is the most important tool to have.
17 Dec 2014 06:00 - 17 Dec 2014 06:01
Item below showing vent tubing between carbs 1-2 & 3-4. On my 81 650-CSR the tubing is routed over the airbox shoulders and fitted snugly between the airbox & side covers; the left side has a frame clamp.
Kawasaki ZN1100B LTD '84-'85 REBUILT CARB ~ BS34 Mikuni KZ1000 KZ1100 V074
Last edit: 17 Dec 2014 06:01 by martin_csr.
