kz550 help
- catastrophe621
04 Dec 2014 07:26 #655322
by catastrophe621
kz550 help was created by catastrophe621
I am getting ready to install pod filters and ive elimanted the air box. I plan on capping off the valve covers, but what do i do with the 2 vacuum lines on the carburetor intake manifolds? Can they just be closed off as well?
- Thank you received: 2829
04 Dec 2014 07:34 #655323
by 650ed
Replied by 650ed on topic kz550 help
Don't toss out the airbox; you may decide to put it back on after a while. Ed
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
04 Dec 2014 09:27 #655328
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic kz550 help
If you have a vacuum petcock, run one of the vacuum lines to it, and cap off the other one. If you remove the airbox, and run pod filters, you will need to rejet. Once you see how much of a pain it is to remove that airbox, and then multiply that by 15 to get it back on, you'll run pod filters all the time.
- Tyrell Corp
- Thank you received: 261
05 Dec 2014 09:43 #655411
by Tyrell Corp
Replied by Tyrell Corp on topic kz550 help
I use fuel pipe to link the inlets 1 and 4 2 and 3 and put a T piece in on one pipe to the vacuum fuel tap.
- Grumpy Ole Artist
- Eschew Obfuscation!
- Thank you received: 62
05 Dec 2014 12:14 #655418
by Grumpy Ole Artist
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Replied by Grumpy Ole Artist on topic kz550 help
Stay dry! ;o)
1978 KZ650 B2
- catastrophe621
08 Dec 2014 06:37 #655631
by catastrophe621
Replied by catastrophe621 on topic kz550 help
I got this i found some large black caps for water pump lines and put those on the valve covers with the spring clips that were already there and then i called the local bike shop and grabbed two caps for the intake manifolds 1and4(2&3should already have them)... the bike shop even took my picture and put it on their website "winter warrior" of the month cuz it was snowing
Attachment KINDLE_CAMERA_1417785069000.jpg not found
Attachment KINDLE_CAMERA_1417785077000.jpg not found
Attachment KINDLE_CAMERA_1417704405000.jpg not found
- !Seymore
- Ride on...
- Thank you received: 69
08 Dec 2014 11:23 #655651
by !Seymore
Hahahaha! Phunny! ...and great call by the shop!
C.
Replied by !Seymore on topic kz550 help
catastrophe621 wrote: ...the bike shop even took my picture and put it on their website "winter warrior" of the month cuz it was snowing
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
