KZ 400 2 to 1 Manifold carburator , mikuni VM 34
- supereightmm
02 Dec 2014 13:05 #655176
by supereightmm
KZ 400 2 to 1 Manifold carburator , mikuni VM 34 was created by supereightmm
Hi Everyone ,
good evening , i recently bough 3 kits of 2 to 1 manifold for the KZ 400 1979 ( european versions ) , to fit with a single Minkuni VM 34 , we made a first test with the carb and a filter pod from K & N , and after a few Kilometres the carburettor starts to Freeze , then once you gas the throttle stays high .. ( needle does not come down from the freezing carb ) .. any ideas , suggestions .. does anyone have the "perfect jetting for this "
i am in Barcelona 0 level humidity normal of a sea side city , never to cold .
- Nebr_Rex
- Thank you received: 300
02 Dec 2014 18:53 #655212
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ 400 2 to 1 Manifold carburator , mikuni VM 34
A pressure drop will cause a reduction in temperature. A pressure increase
will cause a temperature rise. If you don't believe me try fealing the air tank
on an air compressor. It will heat up as it builds pressure. If you open the valve
and release the pressure the temperature drops. You have to much of a pressure
drop. To much velocity.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- supereightmm
02 Dec 2014 23:44 #655218
by supereightmm
Replied by supereightmm on topic KZ 400 2 to 1 Manifold carburator , mikuni VM 34
Hi , thanks for the reply .. so this means if i reduce the air intake ( filter it more ) it will then that cause a reduction in temperature ?
do i have to change anything in the Jetting ?
- Nebr_Rex
03 Dec 2014 03:05 #655222
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
It's the size of the venturi of the carb.
Are you positive of the carb size?
Have you measured it?
Are you sure of engine displacement? It's cast into the front of the cylinder block.
You live by a large body of water and have no humidity?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Thank you received: 797
04 Dec 2014 06:24 - 04 Dec 2014 06:25 #655317
by 531blackbanshee
Replied by 531blackbanshee on topic KZ 400 2 to 1 Manifold carburator , mikuni VM 34
restricting the air will also cause the velocity to go up,thus compounding the problem.
can you try a bigger carb?
Last edit: 04 Dec 2014 06:25 by 531blackbanshee.
