best place for carbs kits!!!
  • steveo_4192003
  • steveo_4192003's Avatar Topic Author
  • 77kz650b-1
06 Jul 2006 10:01
#59662
i want to replace everything it carbs , i did see a place for $17 but cant find it!
anyone know a place to get these cheaper than z1 enterprise?
also whats the two springs for?
1 for air screw and 1 for? pilot jet adjustment?
i only have one spring and it on my air screw/idle,
maybe thats why it run for like 5-10 min then dies out
all help will be greatful!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • wiredgeorge
  • wiredgeorge's Avatar
Re: best place for carbs kits!!!
06 Jul 2006 11:28
#59679
I personally support Z1Enterprises.com when I can because they combine good prices and customer service. I am sure you will be able to find someone who is selling the same kit for a dime less somewhere but when you do find that company, try and find their phone number bwhahaha
The springs? The kit works for a variety of VM24 carb assemblies. Some have pilot fuel mixture screws (sharp pointy screw) and the longer spring goes under that screw. The shorter spring goes under the air screws. Your carbs will use one or the other but not both.
For some reason, the kit pictured shows a longer and shorter air screw but I am not sure I have ever seen a VM24 use the shorter screw which is set deeper into the air screw well in order to get a plug over the top of it. The longer screws can't be capped as they protrude from the well.
  • steveo_4192003
  • 77kz650b-1
06 Jul 2006 13:20
#59690
ok, i did order from z1 enterprize!! first time, and very pleased, $85 w/ shipping awsome deal! (will do more deals with them)
they were very helpful and they even called to tell me i paid for 2nd day air shipping from ups and it would be cheaper to do 2 day ground (fed-x) and i would get it on saturday instead of monday from (ups dont ship on sat) and save me money(few bucks)
my carbs
1977 kz650 b-1 w/ vm24 stock carbs i think!
so i wont need a spring under the pilot? (if i have one on the air adjustment)?
how do i adjust the pilot screw?(is it adjustable)? top screw or bottom?
do i take out the top and usew bottom to adjust or the one on top to adjust it?
could this be why it runs for 5 min then dies?
when it come to carbs i have almost no skills, lol!
im going searching agian now through the archives for more info on my carbs!!
thanks all!!
  • steveo_4192003
  • 77kz650b-1
06 Jul 2006 13:20
#59691
my carbs
thanks all!!
  • steveo_4192003
  • 77kz650b-1
06 Jul 2006 13:20
#59692
sorry about that!!!!
  • wiredgeorge
07 Jul 2006 08:02
#59904
Steve, Your questions were sort of confusing... Do you have a Kaw Factory Service Manual or a Clymers? If not, you had best get one prior to working on the carburetors.
