Vance & Hines Pod Filters?
- almous71
- Newbman
14 Nov 2014 12:43 #653708
by almous71
1981 KZ550-A2
Va.Beach, VA
Vance & Hines Pod Filters? was created by almous71
Hi all. Just got a set of spare carbs for my 550 and these Vance & Hines pods came with:
Anyone familiar with them? Can't find any info about these online. Looks like they're cotton gauze, similar to K&N, so maybe I can clean 'em & oil 'em up. Airbox is off at the moment anyway, so figured I'd give these a shot in the dark before I wrestle with it again. I know... probably gonna be an even bigger PITA, but worth a shot anyway.
Just wondering if anyone has experience with these V&H pods.
Thanks
Attachment vhpod.jpg not found
Thanks
1981 KZ550-A2
Va.Beach, VA
- loudhvx
- Thank you received: 1616
15 Nov 2014 17:47 #653792
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Vance & Hines Pod Filters?
If you don't have bigger jets and adjustable needles, it will mostly be a waste of time. It may run, but I wouldn't recommend riding it with stock jetting. You'd be asking for trouble running that lean.
1981 KZ550 D1 gpz.
Other links.
- almous71
- Newbman
16 Nov 2014 07:26 #653824
by almous71
1981 KZ550-A2
Va.Beach, VA
Replied by almous71 on topic Vance & Hines Pod Filters?
Thanks Lou. I do have adjustables, and I think the jets in this spare set are bigger. I have a drill press if not.
loudhvx wrote: If you don't have bigger jets and adjustable needles, it will mostly be a waste of time. It may run, but I wouldn't recommend riding it with stock jetting. You'd be asking for trouble running that lean.
1981 KZ550-A2
Va.Beach, VA
- loudhvx
16 Nov 2014 08:44 #653827
by loudhvx
1981 KZ550 D1 gpz.
Other links.
I'd be worried about using a press. It would probably be too fast. It needs to be around 60 to 200 RPM.
Set the needles to the third groove from the top as a starting point. And probably start with mains somewhere around 96 to 100, if you have them, If you use the stock pilots, you will probably want slightly larger mains.
1981 KZ550 D1 gpz.
Other links.
- saxjonz
- KawboyZ
- Thank you received: 76
16 Nov 2014 09:17 #653830
by saxjonz
79 LTD B3
Replied by saxjonz on topic Vance & Hines Pod Filters?
I bought these a long long time ago. Still have them. I think they are of the same quality as K&N. They certainly weren't cheap. Side by side they don't look much different. They are not cheaply made by any stretch of the imagination and I would rock them without a doubt. I had them on my kz for years and years.
almous71 wrote: Hi all. Just got a set of spare carbs for my 550 and these Vance & Hines pods came with:
Thanks
79 LTD B3
