1979 kawasaki ltd 1000
- 1760emer
07 Nov 2014 12:34
OK should I leave gas in the tank and carbs treated with stabil or drain it for the winter im hearing different stories.
Emer
- etbike3135
Re: 1979 kawasaki ltd 1000
07 Nov 2014 13:24 - 07 Nov 2014 13:25
Tank full to the top, sea foam added. Drain the carbs
1973 Kawasaki Z1
18 years in dragbikes
Last edit: 07 Nov 2014 13:25 by etbike3135.
- z1kzonly
07 Nov 2014 17:27
Full, marvels mystery oil plus sta-bil. Been using marvels for 40 years. Tanks on my 75 Harley FLH are 25 years old and look like new inside! I live in North East were motorcycle sits for 5-6 months.
- jayrodoh
09 Nov 2014 09:26etbike3135 wrote: Tank full to the top, sea foam added. Drain the carbs
Same here, done this for 10+ years on everything. Tank full to prevent condensation. Drain carbs to eliminate any risk of gumming up. Attempt to start with choke on after draining to ensure you got it all out. If you a have vacuum/auto petcock you'll need to disconnect vacuum line for last step to prevent gas from getting to carbs.
1982 KZ750-M1 CSR
