fuel petcock
  • DruKZ550gpz
  • DruKZ550gpz's Avatar Topic Author
fuel petcock
07 Nov 2014 07:27
#653136
Where exactly does the petcock get vacuum from?
I do not have an air box and there was nothing hooked to it when I bought it.
1982 kz550gpz under construction
pods and dynojet stage 3 jet kit
1985 Suzuki Madura 1200 stock
1997 yzf750r streetfighter
  • martin_csr
  • martin_csr's Avatar
Re: fuel petcock
07 Nov 2014 08:40
#653141
One or more of the carburetors may have a vacuum port --- typically on the engine side of the carb body.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: fuel petcock
07 Nov 2014 09:07
#653146
Not sure on your 550. Some times there's a port on the carb holders between the carbs and the head.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • DruKZ550gpz
Re: fuel petcock
07 Nov 2014 09:44
#653149
I have 3 ports on the engine side that are used to sync the carbs. Can I use that? Should I just use one of them and leave the other two capped?
  • loudhvx
  • loudhvx's Avatar
Re: fuel petcock
07 Nov 2014 09:57 - 07 Nov 2014 10:05
#653152
In order to sync the carbs, there would have to be four ports. You can cap three, and use the fourth for the petcock.
I believe, normally, two of them would have connected to vac hoses for the emission system, above the engine. A third would have gone to the petcock. The fourth would have been capped. Without the Kawasaki website, I can't really look up parts and compare any more, to be sure.
There's a bunch of manuals in my signature. You should grab all of them while you can.
Last edit: 07 Nov 2014 10:05 by loudhvx.
  • martin_csr
Re: fuel petcock
07 Nov 2014 11:19 - 07 Nov 2014 11:31
#653157
He probably doesn't realize one of the ports is already plugged or capped --- probably #3. :)
Partzilla & PowerSportsWarehouse have good diagrams.
Last edit: 07 Nov 2014 11:31 by martin_csr.
  • DruKZ550gpz
Re: fuel petcock
07 Nov 2014 11:51
#653159
Yup. Missed #3 from left while sitting on bike. I used #2 and made sure the rest were capped. Emission system deleted since I have no air box.
Bike runs great once warm. Still needs a lot of work and tires are beat but it was real fun to go around the block on.
thanks,
David
