Carb boot nipples
- New 750
Carb boot nipples
05 Nov 2014 10:17
Each of my two carb boots has a barb Wich I assume was for a vaccume supply for an automatic fuel petcock, mine is manual, the PO had the two carb boot nipples connected via vaccume line, is that correct? Or should I just put a rubber plug on them?
1977 kawasaki KZ750
- Grumpy Ole Artist
- Eschew Obfuscation!
Re: Carb boot nipples
05 Nov 2014 10:59
Rubber caps would look neater but as long as the short line between them doesn't leak, it will do the same thing.
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
06 Nov 2014 05:25
The early 750-Twins came stock w a manual fuel valve (pretty sure). I seem to recall mention of a balancer tube between the carb holders on the 750T, but I don't remember if it was okay to install vacuum caps in its place or not. The cylinder head diagram at Partzilla shows the tube.
